Question about Lexmark T642 Laser Printer
T 642 I have a new T642 Machine and i have printed a few thousand pages and it is squeaking loudly. I took the cartridge out made sure that all the gears were ok and they were. It stoped after puting it back in for about 80 pages then it started agian. What can cause this since it is a new machine i wouldnt think that it is the rollers. They look good and have great grip on the paper. Thanks in advance~R
  • JonT26 Dec 12, 2007
    We also have the same problem on a fairly new T642. It is squeaking more loudly than usual today, and when finished with a print job, it sounds like a roller comes to a sudden stop with one final loud rubbery squeak.
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 1,362 Answers
It is most likely hte cartridge, sometimes the drum will give out a loud squeaking hollow sound, it is annoying but harmless. Try new cartridge if you have one.
also to confirm, take out cartridge and turn gears manually, it should make the noise slightly.
Posted on Nov 16, 2007
If it is squeaking when it is trying to pick up the paper then check the Paper Feed system.
If it is squeeking as it tries to print. Then it will be either the Cartridge or the Drum unit.
If it is squeaking from the back of the machine as the page is fed through the fuser then check the fuser is free moving.
Replacing the faulty unit will fix the squeaking. Be that the Paper Feed System/Drum/Toner/Fuser.
Mar 29, 2016 | Brother Office Equipment & Supplies
My XEROX 6180N printer has vertical white lines running on left side of page and also has starting making loud squeaking noise while printing? Any ideas?
Try a different cartridge. While line typically means that no toner is being applied to the drum in that location. Would also explain the squeaks.
Sep 02, 2015 | Xerox Phaser Office Equipment & Supplies
Load mp feeder error optra t 642 printer
I received this message when I was trying to print a pdf file. I attempted messing with the positioning of green paper guide to no avail. My co-worker suggested I uncheck the Choose paper source by PDF page size box on the Print pop-up box. This did the trick.
Dec 08, 2009 | Lexmark T642 Laser Printer
Print is becoming lighter and lighter. Print cartridges are new. Machine has probably only done a few thousand pages. Help please!
this sounds like a high voltage power supply prolbem i would say change the power supply this should solve your problem
Oct 29, 2009 | Lexmark C522n Laser Printer
When I first print a page of text, it comes out all faded--like when the cartridge is empty, even though I just had the cartridge refilled. When I print the same page again, the text becomes a little...
Ok two things here, the slides need wiping with a cloth, even use a small amount of sewing machine oil on cloth ( SMALL AMOUNT I SAID) then run the machine in cleaning mode and also check the print mode this is in the printer queue module under tools or maintenace.
Jun 20, 2009 | HP DeskJet 845c Printer
Lexmark T642 - print is very light
take the cartridges out and clean the spot they go into then clean them off also
Jan 19, 2009 | Lexmark T642 Laser Printer
Won't print in color
All cartridges are shows 0 pages for yellow left yet all others added at the same time show thousands of pages left. Everything printed is in black with no color. BTW: I have 3,000 pages left with black cartridge and the display says I need black.
What should I do?
Nov 20, 2008 | HP LaserJet 2840 All-In-One Printer
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
Printing Issue - Lexmark T642
Chip on toner is bad, try puting in old one to reset and switch it with new one, sometimes turning off and on several times helps.
Mar 12, 2008 | Lexmark T642 Laser Printer
Optra 642 series
Is it only that document or from any OTHER doc source, word, excel etc.....
Nov 13, 2007 | Lexmark T642 Laser Printer
Lexmark T642 Laser Printer Logo
379 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
