Emerson 32 Inch LED HDTV Logo
j
jesus r garcia Posted on Aug 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After lighting storm it stopped working but blinking red light just under up channel button is on,is there a reset?
Huseyin Huseyin
Level 3:
  • Emerson Master 3,469 Answers
  • Posted on Aug 10, 2015
Huseyin Huseyin
Emerson Master
Level 3:
Answers
3469
Questions
Helped
767022
Points
11197
If there has been a lightning strike near your home it is possible A
best that a technician should take a look at it...there is unlikely to be anything you can do I am afraid. Resetting to factory default is usually achieved through the menus available from your remote control.
Program toshiba tv remote ct-885
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
    Codes to Check:
    013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
    0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
How do I reset URC-3220 w/my tv?
Direct Code Entry
    Code Search Method
UR 2 Universal controller - don't work!
Direct Code Entry
    Code Search Method
2helpful
Philips universal remote codes
Hi Troysingleto. The code can depend on what model of URC you have. According to a site I found by Googling, the code for Apex TVs on one common URC from Philips is 044. Here are the steps to input it directly:
1. Press and hold the Code Search button until the red indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV, DVD, etc). The red indicator blinks, then stays lit.
3. Enter the 3 digit code (044) . Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the device responds, no further programming is required. Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
If that code does not work, you can still find the code using this manual procedure first posted on FixYa by cptnkirk4064:
1. Manually turn on device to be controlled.
2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
3. Press and quickly release the desired code button (TV, VCR, etc). The red indicator light should blink once.
4.Press the "Channel Up" button repeatedly (up to 300 times) until thedevice to be controlled changes channel. The red indicator light shouldblink off with each button press. If you accidentally overshoot therequired code, press the "Channel Down" button to backtrack through thelibrary until the device changes channel. Pressing "Channel Up" changesdirection again.
5. Press and release "Mute" button to install the code.
If you wish to actually identify the code once this has been done, this is the procedure:
1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
3. Press and release the "Code Search" button. The red indicator light goes off.
4.To find the first digit for the code stored under the mode key pressedin "Step 2" press each numeric key from 1-9 in turn. When the redindicator light blinks off, the number you pressed is the first digitfor the code you are searching for.
5. To find the second digit,repeat "Step 4," this time when the red indicator light blinks off,this is the second digit in your number.
6. Repeat again for the third digit in your code number.
Once I find out the code for my TV or DVD player, I write it on a small piece of paper (make sure to note which unit code is for!) and tape it to the inside of the lid to the battery compartment for future reference.
Best of luck!
2answers
Lost owners manual
I do not believe this is available on-line, but have some info that might help you use the remote.
To Search For A Code:
  3. Press and quickly release the desired ode button (TV, VCR, etc.). The red indicator light should blink once.
  4. Press the "Channel Up" button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator light should blink off with each button press. If you accidentally overshoot the required code, press the "Channel Down" button to backtrack through the library until the device changes channel. Pressing "Channel Up" changes direction again.
To Identify The Code That Was Found:
  4. To find the first digit for the code stored under the mode key pressed in "Step 2" press each numeric key from 1-9 in turn. When the red indicator light blinks off, the number you pressed is the first digit for the code you are searching for.
  5. To find the second digit, repeat "Step 4," this time when the red indicator light blinks off, this is the second digit in your number.
I hope this helps out,
Chris
105helpful
7answers
Code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
2answers
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Philips 14inch color power problem
Take it back where you bought it.If its still under warranty, they'll work on it.If its not,they'll still advise.Hope that helps!
Wont turn on
Yes that is an error light. If you give me a minute I will try and get you more info on your tv.
Thanks,
lee
Top Emerson Computers & Internet Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you an Emerson Computer and Internet Expert? Answer questions, earn points and help others
