Question about Acer Aspire 4730-4947 Notebook
Its under my task bar just a small dot few mins
Its under my task bar just a small dot few mins ago but now its like a thumbnail big
2002 Vectra. How do I replace rear handbrake cables?
first thing I would do is BUY a repair manual then read the section about hand brakes . before going out and buying parts . it might lead you to a mechanic . it is not an easy task , if you do not have a lift to get under the car standing up .
Aug 20, 2015 | Cars & Trucks
The sound icon has disappeared from the task bar. I've checked control panel (sounds and audio devices) and the 'place volume icon on task bar' has gone grey and can't be ticked (it was ticked before icon...
hello from a few days ago I was working on my laptop and suddenly reboot. but now get a message that is:
sis UNDI, PXE-2.1
copyright PXE BootROM v1.09f - ZL5_0324 Use BEV/BBS
=== Press <Esc> to bypass LAN check. ====
him and tried to boot from the CD drive. order to retrieve information or other cases formatting. but when the process goes to the information is not in the hard disk.
Aug 17, 2013 | Dell Inspiron 1501 Laptop
Why does the space bar only have a centre touch point
The reason for this happening is that the metal bar under your spacebar is not properly attached. It's time consuming to properly fix it, but it's an easy fix at that.
All you need to do is remove your spacebar and metal bar (shaped somewhat like a tall C, if held sideways). On the bottom of the spacebar will be approximately 2-3 small clips in which the metal bar will snap into. Once snapped into place, you will want to look at the area where the spacebar goes. There should be two small clips at each end. With the metal bar clipped into the spacebar, you want to place the "ends" of the metal bar under the clips on the keyboard and very carefully place the spacebar into the hole on the keyboard and snap it into place. Now test it out and it should work fine. If not, it's likely that the metal bar came out from under the keyboard clips. The annoying part is snapping the spacebar into place without having the metal piece come out from under those clips, so you may need to perform this task a few times.
Here's an example image...
Jul 22, 2013 | Asus Systems Asus X501A Notebook
Task bar displays
Just right click the task bar and click properties and then click customize , then click restore default Over!!!!
Aug 22, 2009 | Microsoft Windows XP Professional SP2 Full...
Can't disable touch pad
Windows hides rarely used icons. If your does, then the task bar shows a left pointing arrow < . Click it and look for the icone for touchpad.
If you cant find that icon,
In WINDOWS XP
1. Start
2. Contol Panel
3. Right click the Mouse icon.
4. Under the Touchpad ON/OFF thumbnail, put a check mark in the disable option.
5. Use the same procedure to enable touchpad
Aug 22, 2009 | Dell F3534 Touchpad
Taskbar problem
drag it to the right then to bottom. first make sure its not "locked" by right clicking it.
Nov 29, 2008 | Computers & Internet
Acer Aspire 4730-4947 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
