I have exactly same problem.
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened.
(that information taken from a link).
Good Luck!!
Thanks
The LE error code is a relatively rare code to be displayed but easily resolved. The error code is displayed only when washing the cat. It is a clever fail safe built in by Samsung and informs me that Tiddles' leg (LE) has been caught in foreign body tray in the door well. Please look out for similar codes pertaining to this situation, HE, TL,
Replace washing machine and never buy again samsung brand, this error makes my day ruined! stupid and poor design!
ther is no overloading as i see there is plenty of space inside the machine, if that is the case then why the machine still started to run??? that suppose to flash the error promptly! all errors should have code listed infront of the machine as researching is time consuming! likewise, water inlet design is very bad, why there is a need to have a double filter, one is enough?? door hinges is not durable, just supported by a plain pin. this model is samsung silver nano 8 kg.
SOURCE: LG Washing machine - WM14225FD. Error LE showing
I tried what I'd seen written elsewhere - my LE error came after I turned the drum as I was unloading it, which caused the control panel to light up. This confused the brain.
I unplugged it for 10 minutes, then started a Rinse & Spin cycle with No Spin selected for the Spin Speed. After this completed, I was able to use the washer as normal.
SOURCE: LE error message when washing. Drum will not spin
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
You can get required parts from
www.repairclinic.com
Thanks. Keep updated for
any more query. You can rate this solution and show your appreciation.
SOURCE: Samsung washing machine shows error "LE"
SOURCE: Samsung J1455AV: Washing cycle does not complete and then stops
go back to where you bought it and have the engineer look at it might have been faulty when bought.
SOURCE: LG Direct Drive 7.0 WD-12126RD Error Code LE
LE indicates a fault with the motor on the appliance.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!
WF7708N6W
My washing machine started normally, but after some time it stopped and shows error "LE".
