? 6:49
https://www.youtube.com/watch?v=GbyHTxzTabY
Mar 15, 2012 - Uploaded by Mrsdarkness2011
Review of hot spa by Helen of troy .... i have this same foot spa. pros: is it can heat cold water, cons: doesn't have adjustable heat temp, not ...
An unbiased review of the Helen Of Troy Hotspa Pro foot bath. Helen Of Troy offers several professional foot spa products and this foot bath has one of the.
Dedicated to delighting the consumer. We aim to make reliable & long lasting products. However, in the unlikely event that your appliance requires servicing ..
THE WATER LINE TO THE DISHWASHER SHOULD BE FROM SAME HOT WATER LINE TO THE SINK. RUN THE HOT WATER IN THE SINK UNTIL HOT THEN TURN ON DISK WASHER AND CHECK THAT THE TEMP IS CLOSE TO SAME TEMP. HAVE SEEN COLD WATER LINE USED. YOU SHOULD BE ABLE TO SEE WHICH LINE THAT THE WATER LINE TO DISHWASHER IS CONNECTED.
On an older model washer, you probably have a bad water valve. (hot water solenoid coil electrically " open ") Newer models, now there's a can of worms. Some models use thermistatically controled water valves to limit water temps, so you may not be able to get true hot water. Also, if you are checking the temp as the machine fills, some models will only fill with cold if the lid is open. (safety feature) The only way to see what is really going on is to fill the machine with cold and use a thermometer to check the water temp, then, pump that out and fill (with the lid closed) with hot and check to see if that temp is higher. As stated previously, water temp may not really be " HOT " but may be warmer than " COLD ". That may be as good as you will be able to do, as all manufacturers are trying to reduce energy consumption. Thank your government.
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
There isn't a temp control on water entering a household dishwasher. The water temp is controled by the actual water heater at the residence. Is is hooked to the hot water side of your nearest sink. Good Luck
id be curious as to the age of this machine, because the newer models have what teh call adaptive water temp sensors that will optimize the water temp automatically.. your hot water may be "too hot" and your cold can be "too cold" and the valve corrects to a preset temp. this sounds like whats happening
most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
hi try to just regulate the temp by turning down the water flow from your taps if more cold is coming in than hot turn cold water down a bit to your satisfaction thanks THE APPLIANCE DOC
washer may not be detecting water temp but water flow ..if you never use hot water may try hooking cold water to a Y-connector and then hooking to both hot and cold inlet valves ..however it is also possible washer is detecting inlet temps in which case you're out of luck ..i suspect the latter
