Question about 3Com (3C16593BN) 24-Port Ethernet Hub
Hello the power supply on the hub has died, what are the output voltages and the pin arrangements on the hub? for the PSU.
  • 339 Answers
The voltage and current ratings should be stamped next to the power jack on the switch. They can be difficult to read so a light and magnifying glass can be helpful.
Posted on Jul 13, 2009
Astec AA23080
You have to "short" two of the sockets.
Get the CORRECT two, or else you could kill yourself, or "fry" the power-supply.
Details: http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm about the "pin-out" arrangement.
It would be easier/safer to connect the sockets to a motherboard, and connect a power-switch to the ON/OFF pins on the motherboard, and then use that power-switch.
Feb 10, 2014 | Computers & Internet
Test a power supply
if your PSU starts (fan is spinning) you can test it with voltmeter. to check voltages for motherboard do next:
1. take PSU out of case
2. put power cable in
3. with some wire connect green and any black on MB connector on PSU (20/24 pins)
4. fan should start spinning
5. use voltmeter to check voltages
this is just basic. real PSU test is when you have device that will burden PSU while testing...
Nov 04, 2012 | Dell Computers & Internet
Power supply not powering on
mine 2 psu running doesn't. false where knowing won't am i?
Aug 08, 2012 | HP Compaq 6000 Pro Microtower PC (NV504UT)...
I have mixed up my power supply for the IH-U582FB with other power supplies. What is the output voltage and is the center pin positive or negative?
Usually on the back of the unit next to the power plug-in there is a small symbol that looks like this -(o+ the circle represents the center pole if the plus sign is beside it then the center pole is positive sometimes the voltage is listed there also if not then look on the label on the bottom and the voltage and amp rating will be found there
Oct 31, 2011 | iHome 4port Netbook Hub Black IHU582FB...
HP P4SD, its running good with 4 gb RAM, P4 3.0ghz, and a couple sata hd. The problem is the fan output voltage, i havent been able to read the output chassis and cpu cooler pins voltage cause i can find...
"i can find my dmm?" did you mean CAN'T?
"its clearly off", what is off?
the fans are 3 pins,2 are power, one is RPM tachometer.
"it all works fine", so you can boot and run any OS, ?
"the voltage reads +12vdc", where, at fan or PSU?
the fans run off 12vdc, they are DC motors (from outside fan)
if the fan runs slow at 12vdc the the fan is bad or is a low RPM
fan, as some are, bigger fans run slow, for less noise.!
first is the CPU fan it must run full speed, if not the CPU will overheat in seconds and ALL CPU shut them selves (by there selves) this way. so CPU fan is first. what does it do... there....?
then BIOS screens. GOT BIOS UP? and running? with, ESC key pressed>.
let me guess your symptoms
1: PC dead. will not boot.
2: BIOS dead.
3: all fans DEAD,.
4: power switch works and all PSU voltages read right, (seems not)/?
5: if the PSU power wire reads right(DMM), matching the side sticker voltages, and the CPU is dead, the MOBO is dead, or CPU is toasted.
here is a modern PSU, sticker.
see 5 to 10 power lines, see them. all must read correctly
if a fan is dead, then its dead if 12vdc is present on the fan power pins.
Apr 28, 2017 | HP Asus Motherboard P4SD-LA Socket 478...
Ive antec pc case with twin 550 psu's there are five sockets
The Power supply willhave to pin #16 connected to pin #15 for an ATX power connector. It would bebest to purchase a Power Supply Tester for about $20.00, which will test allvoltages with a load and give you a go or no go signal. If you want to use ameter to check voltages, here is a link for the pin outs.
http://www.google.com/imgres?imgurl=http://www.smpspowersupply.com/ATX-connectors.JPG&imgrefurl=http://www.smpspowersupply.com/connectors-pinouts.html&h=368&w=478&sz=30&tbnid=nhDjb8Eq1fhorM:&tbnh=99&tbnw=129&prev=/images%3Fq%3Datx%2Bpower%2Bsupply%2Bpinout&hl=en&usg=__4IVO2NEw5aG-llLitG7OvnQVAsY=&sa=X&ei=seVFTL7uEcP7lwehzcHOBA&ved=0CDQQ9QEwBg
Jul 20, 2010 | Antec Neo HE 550-Watt ATX CPU Power Supply
What external power does SmartDisk FireLite FWFL120-N take?
Many USB power supplies will have the right plug. I picked one up by buying a cheap USB hub, What you want to look for (most likely on the bottom of the power supply) is VOLTAGE Output: 5.0 VDC, POWER Output: 1.0 amp or (1000ma) and the center hole is the positive side. I have even seen some BluTooth earpiece charges that supply what you need.
Hope that this will help.
AAirwolf
Jul 05, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
I need the pinout of the jazzy 1103 ultra battery
The Output voltage 24 - 29v ,Usually 27v. (And 4 Amps)
The Pin arrangement is Negative to the Left, Inhibit in the Middle, And Positive to the Right Assuming your looking into the plug itself from the front.
Always check with a Voltmeter first though because there are some chargers with the Opposite Pin Arrangement.
Dec 11, 2009 | Pride Jazzy 1103 Ultra Standard Power...
3Com (3C16593BN) 24-Port Ethernet Hub Logo
138 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
Håkan Sterner
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
