Question about Dell Dimension 5100 (D51L1) PC Desktop
I can't insert any cd's.
Whenever I try to insert cd/dvd's the laptop takes the cd, but then makes this weird vibrating sound, and then ejects it. Anyone know what's wrong?
    Problem Solver:
  • 5 Answers
Check whether your laptop has dvd-rom or cd-rom. cd-rom cannot read dvd. so, you have to buy a dvd-rom. other case, maybe your cd/dvd corrupted.
Posted on Jul 12, 2009
  • 198 Answers
Maybe the laser eye is jammed. It tracks back and forth reading data from the disc.
You may either replace the drive or have it repaired.
I had one on my PC do the same vibrating, clicking noise. It only cost 40.00 to replace.
But for a laptop, you're looking between 60-100 dollars to replace.
You can see how much it would cost to repair first, but my guess is it would be cheaper to replace.
Whenever i put a dvd/cd in my hp probook 4510s and try to open it, it insteads ejects
Remove the Power Cord, Remove the Battery, then close the lid and turn the laptop over and remove the one screw that holds the dvd drive in place on the bottom of the laptop. Remove the Dvd Drive and in about 20 seconds put it back in and Try rebooting to see if it solves the problem.
Your dvd drive might be defective and needs to be replaced. You can find one on ebay. Just put HP Probook 4510s DvD drive in the search.
Once you take the dvd drive out you can also search on the model of the dvd drive. The model will be listed on the dvd drive.
May 12, 2012 | HP ProBook 4510s Notebook
It will not let me insert a disc and when I press the eject button, it sounds like it is going to eject a disc and then it makes a weird noise for 5 seconds. Then, it will say CLOSE for a bit. I got one...
It sounds like you have 2 disks stuck in there. TV repair shop, or try shaking the dvd player lightly while dvd is trying to open. You may need to help open the door, but too much effort could cause harm.
Jul 08, 2011 | Samsung BD-UP5000 Blu-ray and HD-DVD...
The laptop burned a disc, then ejected as usual. Another disc was place in the tray, inserted as normal but this time a cd was unable to be burned because the laptop did not recognize the disc or any other...
The automatic ejection takes place when the burn process has completed successfully. Have your tried another writable CD or DVD? If your laptop is not recognizing any more writable CDs/DVDs, then the problem might be a failed CD/DVD drive. Otherwise, it is probably a bad CD or DVD.
Hope this helps.
May 26, 2011 | Computers & Internet
Dvd won't eject. It lights up flashing like wants to open. I tried to eject dvd every way possible ie., computer link, etc
All CD / DVD drives have a Eject Pin Hole. The only thing we need is a paper clip to use it
All we have to do is bend it at the first curve 180 degrees (straitening it out). Then take the second curve and bend it 90 degrees. Now we need to locate the Eject Pin Hole.
Laptop - Notebook CD / DVD drives:
The trays on laptops/notebooks are spring loaded, so all that is needed is to release the locking mechanism. You do not have to insert the paper clip as far as with a desktop CD / DVD drive, as you are not connecting to the gearing under the tray. Gently insert the paper clip into the Eject Pin Hole. Once you feel it make contact, gently push in and the tray will eject immediately. Once done, gently push the tray back inward until it locks back into place.
Desktop CD / DVD drives:
Gently insert the modified paper clip into the Eject Pin Hole until you feel it make contact with the gear underneath the tray. Firmly pressing inward, you will notice the tray to start to move out. Press inward until you have enough room to get your finger under the tray and then pull it out the rest of the way. If you can only get a small portion of the tray out, you can use the other end of the paper clip to gently pry open the tray enough to get your finger under it. Once done, gently push back the tray to the closed position. It will close firmly when the system is powered up.
Mar 14, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Making crakling sound and spits cd back out. won't
First thing you should do was to do a diagnostic in F12 run the diagnostic for CD DVD so that you could verify the functionality of the parts. It's still in warranty you can still asked for repair or system exchange .
ERNZ
Feb 03, 2010 | Dell Studio 17 Laptop
CD drive clicking sound
Hello my friend please try to insert 2 new CD. and then try to observe the sound if it is still sounds like the weird. Then if you notice that the 2 new CD you insert produce same sound as your old one then i recommend that if you can find computer technician in your place to verify if your DVD/CD Rom is defective or not cause as of now if the 2 new cd inserted produces same sound as your old cd inserted then DVD/CD Rom has something to do its either defective or has a serious problem that needs assistance.
Thank you
Jul 30, 2009 | Computers & Internet
CD won't eject. I have tried the button on the drive and clicking the eject through the software. The light lights up and there is a whirring sound, but then nothing.
your cd rom tray is stuck inside may be due to a hardware error please take a paper clip and make it straight now insert this clip in a small hole located at the front panel of your cd rom drive..apply some pressure and the tray will be ejected/..
Thnx and i hope this helps
Please rate this solution
Jul 16, 2009 | Dell (0F146) Internal DVD Drive
No cd or dvd is played by my laptop
Hi there.
It sounds like the drivers could be bad or the lens has gone.
This can be a common problem with vista loosing the CD/DVD drives.
Do this >>>>>> right click on "computer" and select "manage" from the sub menu, then select "device manager" from the left hand side, it will generate a list of devices, look down the list for CD/DVD and click on the + icon next to it, from the drop down list right click and uninstall, restart the PC and let vista re-install the drivers for you, then try to use the CD/DVD.
If this does not work please post back.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | Computers & Internet
Weird clacking sound in the cd drive of Dell Studio laptop
if it is new I suggest that you call Dell Customer support.  It is Free and they are very good.
Jan 14, 2009 | Dell Studio 15 Laptop
DVD drive troubleshooting
Can you explain a dvd cartridge please?
May 04, 2007 | Panasonic LF D521 (LF-D521U)...
Dell Dimension 5100 (D51L1) PC Desktop Logo
75 people viewed this question
Clive
Clive
Alun Cox
