Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
FRIDGE IS NOT COOLING AND FROST DEVELOPING IN THE FREEZER
    Sergeant:
    Champion:
  • 235 Answers
Manually start timer and see if this activates the defrost. If it does then the timer is out. If it doesn't then the t-stat or defrost element is out. These are in expensive parts and not a hard task for the diy.
Posted on Jul 12, 2009
Fridge s/s cool on freezer but no air cooling fridge side
First, inspect the back wall of the freezer for frost build-up. Defrost failures are a common cause for incorrect fridge temps, and the frost will block air-flow even if your damper is wide open. if there is no frost, verify that the evaporator fan in the freezer is spinning, THEN check the damper door to see if it is open during cooling. Call a tech, guessing will likely lead to a broken machine and/or tons of wasted money!
Apr 26, 2016 | Refrigerators
Electrolux frost free fridge freezer. Warm fridge and ice in the frost free freezer?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 22, 2010 | Heating & Cooling
Continously running without stopping
Needs a new thermostat. Get engineer to fit for you. Cheers, Derek.
May 19, 2009 | Jenn-Air JCD2389G Side by Side...
Refrigerator Compartment not cooling properly: freezer compartment working properly
Check the freezer section for frost build up, there is probably a problem with the defrost cycle. 1 of 3 things defrost bi metal would be the likely problem.The back panel in the freezer should be removed to see if there is too much frost.
May 01, 2009 | Frigidaire FRT18S6AW Top Freezer...
Frost free fridge/freezer - not cold in fridge
The most common problem with refrigerators not cooling when the freezer cooling is the fan which supplies cold air to the freezer. Not easy to get to in most cases. Another problem is the vent to the fridge part is blocked or not operating with the adjustment control.
Nov 27, 2008 | Freezers
I have a zanussi fridge freezer combination, it is a frost free model, Im developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does...
Hello Mr Barnard
Welcome to fixya
You said, You have a zanussi fridge freezer combination, it is a frost free model, And you're developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
Frost could mean a few things.
Is the freezer cold but the fridge not?
If so the freezer may be so full that the articles are covering the air vents in the back that share the cold air with the fridge.
I've have seen the freezers packed to the hilt!
More things to check.
Is the condenser in the back or under the front of the fridge. If it is under the front of the fridge you must remove the plastic grill`(The condenser is the thin black metal tubing that runs back and forth to make up your condenser). This needs to be free of dust and have air passing over and through it!
they sell refrigerator brushes for this at the hardware store.
I have had customers that never ran the brush under there ever and had 1 to 2 inches of dust and lint
under there between the tubes.After a few hours it was cool the next day it was cold!
The freon level pressure should be checked in case you have a leak.
The thermostat may be bad.
Let me know what works for you.
Huuum
Please remember to leave a rating!
Oct 05, 2008 | Refrigerators
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
361 people viewed this question
Top Fisher and Paykel Refrigerators Experts
John Tripp
John Tripp
Carmen Mikulic
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
