Question about Dell 1707FPv Monitor
The monitor shows 3 times under Device Manager. Is
The monitor (1707FPV) shows 3 times under Device Manager. Is this correct or could it be thwe reason my computer takes a while to boot?
    Problem Solver:
  • 15 Answers
Check this link for explanation:
http://forum.soft32.com/windows/Multiple-Display-Adapters-Monitors-Device-Manager-ftopict354735.html
regarding the slow performance go to start-->run-->msconfig-->under services tab-->Check Hide All Microsoft Services then uncheck all unnecessary programs then click ok. under startup tab uncheck everything except the antivirus, wireless (if your using one) and other important program.
Posted on Jul 12, 2009
When I plug in the flash drive it lights up but doesn't show up as a drive in "my computer". If I start the device manager (which shows the cruzer device as a funtional drive), disable it and...
STEP 1 - Connect the Cruzer to the PC
If you receive a "USB Device Not Recognized" error on the computer, the flash drive is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: The Cruzer might show up under several places under Device Manager such as:
1. Disk Drives
2. DVD/CD-ROM drives
3. Universal Serial Bus controls as USB Mass Storage.
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click on the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
STEP 4 - Verify if the flash drive is detected
1. Double-click My Computer.
2. Look for the Cruzer under devices with removable storage.
SOLUTION 4 -
There might be a conflict in drive letters, see Resolving drive letter conflict.
Oct 26, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Moniter keeps turning off saying no video imput
Hello and Welcome to FixYa!
Check that the Input signal cable is properly inserted in the VGA socket. Secondly the Primary VGA is properly giving display signals to the Monitor/LCD. Because there are cases in which VGA is the bottle neck of the trouble you are facing.
Cross check and update me with the status,
Best of Luck,
Do RATE the solution, If found Helpful,
Concerned.
Jun 13, 2010 | HP vp17 Monitor
1) I have a Toshiba Pro 600 model ps600c-01qw4. The problem of this laptop is that when i turn the computer on the screen is very small. So I went into the display setting and fix the problem. But when i...
Check the monitor in the device manager. NOT regular display properties. Make sure the monitor is the correct type. Try different settings in device manager for the monitor. Maybe try uninstalling the video card drivers, reboot and reinstall the drivers. Let me know if this does not work.
Joe
May 17, 2010 | Computers & Internet
My network adoptor is not working
Check whether the network adaptor is disabled in device manager. Enable thwe same may solve your problem.
Nov 03, 2009 | Computers & Internet
How to open the Dell 1707FPV flat monitor? Thanks
lanhqua, If you visit youtube you can see video clips (8-12min) of some LCD monitors being disassembled for servicing/repair.... May I ask what you will do if u get inside your DELL 1707FPV???? Do you know what to look for? Bye for now. louie12fix on fixya or lmistyrel @ aol.com
Sep 25, 2009 | Dell 1707FPv Monitor
Multiple monitor feature
Boot to SAFE mode, go to device manager, remove all Monitors, reboot and let it re-detect. That should resolve you resolution issue.
Jun 24, 2009 | Dell Latitude C510 Notebook
Monitor goes to sleep and never wakes up
I have called HP Technical Support 6 times about this issue and have logged at least 14 hours into the issue. The things they have done are turn all sleep settings in the "Power Options" in the control panel to "never". The problem persisted. Today, they sent my problem to the complaints department, so maybe they will have the authority to do something for my 5 week old setup.
For me, the monitor was in the "other devices" part on the device manager (go to start menu and type device, and the device manager will show up). I went to HP's website to the support and drivers spot and found a patch for the My Display program. This will allow you to uninstall your monitor, just right click the monitor under "other devices" and click uninstall. After you uninstall, restart and your computer will recognize the and put it under "monitors" in the device manager with the updated drivers. After I did this, the monitor hasn't gone to sleep.
Jan 24, 2009 | HP w2207 Monitor
Secondary monitor
When you first switch on Does it show Benq?If not the inverter circuit has failed.If you are technically able you can try resoldering transistors on inverter board.If your display is black all of the time transistors could have failed as also related fuse etc.
And yes please check with BenQ Normally these have a 3 year warranty.
Mar 05, 2008 | BenQ FP757 Monitor
Brown horizontal lines sporadically appearing on monitor
I had the same problem. I fixed it completely today. The horizontal lines disappeared. IT IS DEFINETLY THE DEVICE DRIVER. I confirmed my monitor model tyope (dell M783s) and downloaded the specific driver for this monitor.
I had to do these exact steps or did not work.
1) with the problem screen, disabled the display adapter under the Hardware/Device Manager settings.
2) Restart the PC
3) Boot will come up with brown lines still but the screen will low resolution of 600x800.
4) Then I installed the correct device display monitor driver onto the pc. ( you may need to scan for new hardware, then choose the directory with the new hard drive.)
If you need step by step... just reply back.
Dec 02, 2007 | Dell M781S Monitor
Sva 15" flat screen monitor
You have a bad power supply capacitor or two. Very common. Not worth fixing, these are free on craigslist *replacement monitors like this
Oct 27, 2007 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Dell 1707FPv Monitor Logo
67 people viewed this question
Clive
Clive
Alun Cox
