Question about Sanyo DS27510 27" TV
How do i reset the tv to remove v-guide settings
Good evening, We have a "not so smart Samsung TV anymore", or there must be another reason why the TV guide is not available anymore. Thanks Dirk
Look at your TV manual and look for a procedure to do a hard reset or factory reset, this might get you tv guide back.
Remember that the TV guide are sent by the broadcaster.
May 12, 2018 | Samsung Televison & Video
Will not switch from guide to tv
Did you try power cycling the box?
Aug 28, 2013 | Alba DVBT set top box
553SV Vizio TVand forgot the passcode. Anyway to retrieve it ? Or reset to factory settings
System Info
Display the technical information including model name, version and
revision of firmware, source type, and resolution.
Reset TV Settings
Return all Picture and Audio settings to factory default. A screen will come
up to confirm your selection or to cancel it. Press Left or Right Navigation
buttons to make the selection, and then press OK to accept it.
Note: This does NOT reset the Parental Control Password.
Clear Memory (Factory Default)
Use this function to reset the TV to the default factory settings. The screen
will display a message to confirm that you want to reset the values to
factory settings. Press ? or ? to make the selection, and then press OK to
accept it.
Guided Setup
Use this function to return to the Initial Setup menu. Use this function if you
want to have a guided setup when you move your TV. Refer to Chapter 3 for more information.
Note: Previously scanned channels will be removed.
Aug 16, 2011 | Vizio P2 42 in. HD-Ready Plasma Television
Pioneer plasma elite pro-504pu how do reset to factory mode on standby mode >??
hi,
u cam reset ur only by the following way.
p { margin-bottom: 0.21cm; }
In order to enter Service Mode, TV guide must be turned off
In order to do this procedure you must have and use the correct remote. The full function remote that
came with the set has a TV Guide Logo in a red box. This is the remote you should use.
NOTE: If TV guide has not yet been setup, then the 1st step is to follow instructions to set TV guide up.
Enter ZIP code, cable or ant. Etc.
1.press and release the "TV Guide". TV guide will appear on the screen.
2.Navigate to the TV Guide tool bar and use the ">" button to select "setup" in the menu and press
and release the "enter" button
3.use the "arrow down" button to select "default options"
4.press and release the "enter" button and select "general defaults"
5.press and release the "enter" button (opens menu on lower left side)
6. use the "arrow down" button to select "auto guide"
7. use the ">" button to select "off"
8. use the "arrow down" button to select "done"
9. press and release the "enter"
10. press and release the "TV Guide" button to turn the display off
System Reset Using Service Mode:
1. Enter Service Mode
2. Use the "muting" button to select "initialize" screen
3. While on the "initialize" screen
4. Use the "down arrow" button to select "final setup"
5. Press and release the "enter" button to select "data reset"
6. Use the ">" button on the remote to select "yes"
7. Press and hold the "enter" button until the screen goes black release "enter" button on remote.
8. Power the unit off using the remote control
9. Unplug the power cord from the media receiver to complete the reset
10. Plug in the media receiver; turn the system on and reset is complete.
ok
Jan 11, 2011 | Pioneer Televison & Video
Tv stuck on aux channel cannot program universal remote
Check the guide and see if the codes can be set directly to mesh with the TV frequency.
Also try to remove plug after switch off for some time -it might reset to default condition.
Sep 11, 2010 | Emerson EWF2703 27" TV
Tv comes on for about two min and then turns off, can not goto any devices just a blue screen, but will let you set up chanel guide
if this set has a slot in the back for a cable card---unplug the set and remove the card---it is for HD channels---if set works with card removed--get a new card---they get messed up by upgrades and other problems--if the cable card is causing the problem--set will work normal on non HD channels with it removed
Aug 06, 2009 | Mitsubishi WD62627 62" HDTV
Orange light on the front of the TV
Replaced bulb for zenith e44w46 lcd but the orange light is still on how can I reset the bulb timer on my own without throwing down another 85.00 for a repair guy to reset my T.V.
Jan 26, 2009 | Zenith E44W46LCD 44" Rear Projection...
Panasonic dmr-eh50 Clock setting greyed out - unable to reset clock after clocks went back.
To resolve this issue follow the steps below:
(1) Remove all discs from the unit.
(2) Set the unit to DVD Mode
(3) From the front panel of the unit, open the middle door to display the up and down channel buttons
(4) Press and hold both the up and down channel buttons until the unit displays "BYE" and then flashes "12:00 A"
(5) Release the up and down channel buttons
(6) This will clear the unit and you will be prompted to reset the TV Guide Settings
(7) Setup your TV Guide according to the on screen display
(8) From your remote select "SETUP"
(9) Scroll down to "Setup", right arrow to the options on the right, and down arrow to "Clock Settings"
(10) Select "Set Clock Manually" if your TV Guide Function is not providing you with the proper time
Good luck!!!
Oct 26, 2008 | Televison & Video
TV Guide reset
Try this (with the original remote): Reset TV Guide On Screen
1. Press the TV Guide button
2. Curser up and over to the SETUP menu
3. Select Change system settings (highlight only)
4. Enter the following numbers … 753159852 (setup mode)
5. Enter the following numbers … 653274147 (reset mode)
It will take some time to get the guide downloaded, but it works.
Oct 06, 2006 | Pioneer DVR-633H-S
TV GUIDE
Sometimes this can be cause by a intermittant power strip or extension cord.. Check it out and please report back?.
Oct 05, 2006 | Pioneer DVR-633H-S
Sanyo DS27510 27" TV Logo
490 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
