Question about Saws
I am running a six inch blade width horizontal band saw in a sawmilling application, resawing flitches to thinner boards. Average depth of cut about eight inches. What blade life (swage set steel) should I get before changing and dressing?
  • Anonymous Mar 27, 2014
    model H250
  • 26 Answers
This depends on the type of wood you are cutting. Hardwoods , like oak, will dull the blades faster and require a change after about 3 months if used daily 8x7 but you can get a longer cutting time IF the blades are carbide steel. You can add life to the saw teeth by keeping them clean and free of sap buildup too.
Specially when cutting pine.
Posted on Jul 12, 2009
10 inch Jet Bandsaw, cannot resaw hard woods, blade stops
if blade stops tunring then it's one of two adjustments need to be made , 1st blade tension this is set with hand screw on left side of top part ,2nd the speed of cut is too great , adjust the speed control for the hydraulic clyinder that holds top carrage to bottom , just behind the middle of unit to alllow for slower blade desent , these pistons do go bad ive replaced mine before ,
Jan 21, 2015 | Jet J-7040M 10-Inch by 16-Inch Three Phase...
How long is the saw blade on a 12inch band saw
The manual says that it will support blade widths from 1/8 inch to 1/2 inch. You can use 80" or 80 1/2" band saw blade. I got my band saw blade on sawblade.com . I like them .
Jun 06, 2014 | Craftsman 12 Inch Band Sawsander I2 X80...
What is the best band saw blade for cutting metal
Hey , I read this blog and it helped me a lot in choosing the correct saw blade in my cutting application. This might help you .
http://bandsawblog.com/choosing-the-right-blade-for-your-cutting-application/
Try checking this site : sawblade.com . :) Hope this will help you .
jack
Nov 07, 2012 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Mt 18 inch horizontal band saw is not cutting square
Thicker metal shows greater blade / saw adjustment errors. A simple 1/64 or 1/32 wont show much on an 1/8 thick piece of metal when cut.
Those numbers will double quickly as the cutting blade travels through thick metal.
Metal band saws seem to be trickier to adjust and fine tune because the blade seems to be twisted into the roller guides.
The downloaded manual for the saw that looked most like mine at grizzly.com helped my adjustments a lot.
The saw quality is also a factor.
Dec 18, 2010 | Saws
In the Market for a better Band Saw
Everybody wants to resaw, but the only saw I've seen that will do it is a resaw, they are big, powerful machines. I have an old delta 14, with an aftermarket 1 hp motor, trying to resaw is a nightmare. I don't try anymore. Jet makes a big resaw, so does grizzly, both Taiwan machines, what isn't>? But they work. If you are lucky enough to find an old bandsaw with 36 inch wheels and a ten HP motor, that would be nice, you could resaw whole cars in that thing.!I The $300 special might be worth getting and customizing to work, You would need a big blade, about 1 inch min, and a bigger motor, say 2HP min, Then hope that the tracking system will take the heavy cuts. When I have to slice something , I do it first on the table saw, cut both sides, then run it through the band saw at its max cut, 6 1/2 inches, then plow it through the planer. Always a way around this stuff. Hope this helps.
Mar 01, 2010 | Ridgid 14" Band Saw with Stand
My KING KC-115C Horizontal metal cutting band saw cuts off track.
I used to work for Doall saw company. While I am not familiar with the particular model you have, I have seen issues like it in Doall saws.
Firstly, If bearing guides are not adjustable, replace them. There should be only about a 32 of an inch play between them (in addition to the thickness of the blade). Secondly, for a prodution horizontal bandsaw you should have the blade tensioned a @30,000 psi. Thirdly, if after that, you are still having problems, I would suggest checking the bearings on your drive and idler wheels for runout (in addition to the condition of the tires).
Nov 18, 2009 | EZQuest King (K529900) Burner
Ryobi Bandsaw model EBW4023L will not cut straight
I do a lot of resawing with mine and I have found that a 3/8" wide blade gives me nice straight cuts.
Jun 19, 2009 | Ryobi 9 in. Benchtop Band Saw
Blade Types
remember to match the blade width to the type of cutting you are doing. Also keep in mind: * Narrow Blades can make much tighter radius cuts, but tend to twist and wander when making long straight cuts. * Wide Blades can't make the tight turns that narrow ones can, but they hold a straighter line than their narrow counterparts. * The tpi determines the speed with which the blade cuts through stock. Blades with high tpi cut slower but leave a very smooth edge. They are best for detail work on thin stock. Blades with low tpi cut quickly and leave a slightly rough edge. They are great for resawing or long rip cuts. * Steel Blades are inexpensive and work well for cutting softwood. Steel blades, however, dull quickly in hardwood. * Bimetal Blades are made of high-speed steel and can cut thin metal or wood. * Carbide Blades are for wood cutting only. They are more expensive than other blades but stay sharper longer than steel or high-speed steel.
Aug 27, 2008 | Dewalt Variable Speed Deep Cut Band Saw...
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Blade size
There are two common blades: Eight-Inch Table Saws are a good choice for crafts and other applications associated with thinner stock.Ten-Inch Table Saws provide the extra cutting depth needed for angled cuts in thicker stock.
Aug 27, 2008 | Jet 708315BTC Jbts 10BT 3 15 Amp Benchtop...
Saws Logo
88 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
