Question about Brother MFC 210C All-In-One InkJet Printer
Remove print head
Is there a simple way to remove print head, before I start removing every screw I see?
  • yoddle Dec 20, 2007
    Need to take out print head would like enxplanation of how to.
  • PeterHansler Jan 06, 2008
    I wasted my time and proved your point. I removed the head and did succeed in making it cleaner. But once together error message "Cannot initiate" is all I can get out of it. Gave up and bought another one.
  • Brother Master
  • 1,113 Answers
There is no point in removeing a brother print head unless one is replacing it with new, not cleanable totally different print system to most brands. Head burns out heater elements, rather than blocks.
Yes remove every screw in top cover, all cables and post.
print head detached from rail by sliding to left end then back and up.
You are wasting your time trying to clean a brother type print head.
Posted on Jan 06, 2008
  • 3 more comments
  • Soulvisitor
    Soulvisitor Jan 07, 2008
    These printers are impossible to fix without a steady stream of parts to throw in them and then it still aint easy!
    Enjoy your new printer be very cautious when using after market ink supplies, modern printers are vey fussy with their diets.
  • Soulvisitor
    Time wasting.......... but you missed all the fun, you still had another 3 or 4 errors to go, till you got it going, wasted 4 inks, and found it still wouldn't print properly.
  • Soulvisitor
    please rate mate:-)
  • nikko Oct 04, 2012
    HP and others are using heater elements. They are easyer to clean than EPSON wich use piezo technologies. Try to clean and change printheads if it don't work.
    Error, Brother use piezo, like epson.
Thanks saved my time
Posted on Apr 08, 2008
Replaced black, would not print black, deep clean times two and still the same problem. What can I do?
Hi, the print head needs to be removed and washed with warm water, Please check the manual for print head removal and re-installation. Also print head alignment must be done on re-installation. The process sounds complicating but is quite simple. Do as if you are replacing a ink cartridge. When the print head is at centre in this process and stops.Switch power off on printer.Remove the cartridges, then remove the print head, wash in warm water carefully, do not use any brush or do hard rubbing, dab dry on paper towel. Replace print head into printer, then cartridges, then switch power on. Do print head alignment, clean print head once and print test pattern. Hope this helps as it has worked for me and is still working. All the best.
Mar 10, 2015 | Canon PIXMA MG5420 Inkjet Photo All-in-One
How to change liscense plate bulb
it`s very simple-- above lic. plate you will see the light lens. There may be 2 phillips screws, if there are just remove them and use a small flat head scewredriver to pop it open. Then remove the ``penut`` bulb. If there are no phillip screws, then use the flat head to pop the lens.
Also before you start lift the trunk open and see if you can access the bulbs from in there.
Good luck-it is very simple..
Feb 25, 2011 | 2003 Pontiac Sunfire
How do you change the laser print head assembly on a lexmark t640n
Shenanigans!
I've been fixing Lexmark T640's for a week now and Print Heads are easy!!! Don't let someone scare you into thinking you can't do it yourself just so they get more business and can over charge you to repair something!
1. Remove side and top covers
2. Remove cover for System Board
3. Unplug 7-pin connector from System Board. It's 6-white 1-black wires.
4. Remove connectors from Print Head, should be 2. 1 in front, 1 in rear.
5. Remove the 4 screws holding down the Print Head
6. Take out print head and insert new one.
7. Install by following directions in reverse! :-)
May 04, 2010 | Lexmark T640 Laser Printer
How do I change the tumbler belt on a MayTag DE410 Electric Dryer?
simple remove the two phillips head screws at the bottom of the front panel lift up from the bottom and remove the front panel don't forget to unplug the two wires that go to the door switch and set the front panel aside remove the 4 5/16 inch screws that hold the bulk head on remove the front bulk head and set it aside take out your old belt ,put your new belt around the tube and run it around your spring loaded tension roller and around the motor pulley reassemble the dryer and test thats it
Apr 03, 2010 | Maytag Dryers
I have a xerox 8200 with a faulty printhead and I'm attempting to replace it, the instructions say to remove the top cover but not more. How do I remove the top cover? I figured out how to remove the side...
Weird directions. You to have to remove the side covers. The top cover is the ink loader. The tray where you install your ink sticks. You need a thin flat blade screw driver to remove it. There are no screws just some tabs on the sides that you have to release and it lifts out. Pretty easy. There are 1 or 2 plugs to disconnect on the ink loader. Then remove the print block. and the 2 spring clips on the sides of the print head. It really is an easy replacement. But DO NOT under any circumstances touch the jets , the front plate of the print head.
There are no screws to take out the ink loader once you have the side covers off.
Feb 15, 2010 | Xerox Phaser 8400 Laser Printer
Brother MFC-620CN print head clogged
Open up amd release blue stay at bottom by pressing edges inward and pulling slightly forward. Remove the 4 screws, 2 small plastic covers and the earth screw. Pull out the ribbon connector near the USB plug. Unplug the 2 white and one red connectors, noting how the cables fit in. Fully open the lid and pop the scanner part off. Remove all the ink cartridges. Now using a flat screwdriver unclip the top of the base all the way round and lift off. The print head is now accessible. Rotate the white paper feed cogs to release the print head. Slide it all the way to the right and remove it by tilting the back edge upwards. You mow have access to the print head!!!!
Apr 09, 2009 | Brother MFC 420CN All-In-One InkJet...
Xerox C2424 with error code 07,010.43.3611. What should I do
One of 2 things. Most of the time, the print head block becomes contaminated with ink from the machine not sitting level. Some seeps out of the print head or the cleaning tray.
The other possibility is if the machine was powered down improperly the print head wiper blade is tacked to the print head.
Either way the fault is caused by the print head not bein able to move side to side or front ot back properly.Soooooo how do you get to it.
First remove the power, the on the right side of the machine where the power cord plugs in, 1 remove the power cord, then remove the document feeder/scanner cable. Loosten the 2 thumb screws on the molex connector and remove that plug, it is mounted vertically so when you go to reattach it, it can be a pain and the lower screw is sometimes difficult to get tight, so use a screwdriver to get it snug.
Go to the back of the machine and there are 2 metal tabs that hold the scanner document feeder in place. Slide the assemnbly back as you release those tabs, remove the scanner/feeder assembly and set it aside. To get to the block you will have to remove the side covers only, that is one screw each on the upper back of the covers, right where you slid the scan/feed assembly off. You will think there are more screws to remove, but there are not. What you do is go to the side of the machine and lift up and out on the cover, you have to lift up on the very top edge of the covers to pop the tabs off the frame, NOTE the front cover will also pop off, that is what holds those 2 covers in place on the front of the machine.
Once you get the covers off, Looking from the FRONT now, go to the left side of the machine, You will see about 2/3rd of the way back on the lower portion of the frame a 1 in x 1 in stainless steel block with a 1/2 inch or so shaft running through it. Ther is a spring assembly over it, that just pulls out and up to the left and clips on there for removal of the block. Please rememeber to put that spring assembly back in place when reassembling. My thoughts are that when you look in that block, you will see a lot of yellow ink built up in it, You may have to pick at some of the built up ink to get to the print block and most likely it will be very tight,and will require the use of some channel locking pliers to remove the block. Take your time, twist in a clockwise then counterclockwise motion to losten the block and pull itout toward you. Soak it in hot water to losten the ink and clean it until all the ink is removed. Also clean the print head shaft as best you can and remove any residual ink in the machine. If that indeed is the problem, once that is cleaned well and the block is loose around the shaft you can reassamble the machind and return it to service.
Now if the wiper is tacked to the print head, you will then have to remove the ink loader. That is where you put the ink sticks. To do that, you remove the small white cover that runs across the upper back length og the machine, it has 2 screws holding it in, and also the metal bracket under it comes off. To remove the ink loader, there are plastic tabs on the right and left sides to release to lift it up, then disconnect the 2 connectors to the ink loader and remove it. Once you do that, you have acess to the print head drum area. Look between the print head and the drum, there is a pinkish color blade that would be stuck to eht print head. Gently release it from the print head and reassamble. Then one you do that, run the remove light streaks and remove smears modes on the machine.
One of those 2 items is most likely your problem. In order the print block is the problem about 75 percent of the time, the blade tacking about 15 percent of the time and the other 10 percent is the wiper clutch.
Let me know, we can resolve this one.
Jan 29, 2009 | Xerox Office Equipment & Supplies
Ibm infoprint 1332`
It's quite straight forward
1. Remove the left door.
2. Remove the right cover
3. Remove the paper support
4. Remove the redrive cap
5. Press the fuser wiper cover latch and remove the cover.
6. Remove the top cover screws
7. Remove the paper bin full sensor flag assembly from the mounting bracket
8. Remove top cover.
9. Remove 3 screws and the cables, the printhead will now come out.
10. After replacing the printhead run some test prints with the cover off, loosen the 3 screws holding the printhead to make any adjustments needed to insure the print is straight.
Jun 18, 2008 | IBM Infoprint 1332 Laser Printer
How to remove printhead from canon i860
The gray-colored arm (it's not that small) is to the right of the cyan cartridge. It is the arm or extension of the gray-colored hinged cover. Remove all ink cartridges, lift the gray-colored arm up, and pull the print head out. Clean the print head with a cotton ball soaked with water or rubbing alcohol. Dry and re-install the print head.
Feb 01, 2008 | Canon Pixma MP500 All-In-One InkJet...
How to remove print head of epson stylus photo r1800
Had the same problem - but the print head is actually easy to remove.
1) Remove ink cartridges
2) Remove 3 Phillips head screws at the bottom of the cartridge housing. (looking down from the printer front - top left, bottom left, top right).
3) There are 2 small plastic tabs on a plastic bracket that secure the flex cable on the right hand side of the cartridge housing. Gently release the tabs with a small flat head screw driver.
4) Lift the print head straight up (don't pull on the flex).
There may be a release for the flex to separate from the print head. But I did not see one. Instead I poured 1/4" of Windex in the bottom of a small plastic container and soaked my print head for about 15 minutes (occasionally agitating).
Then put back in reverse order - be sure to seat the flex in the guide (top-back-right) of the cartridge housing before screwing down. Then run a cleaning or two to flush the cleaning fluid out of the print head. (I have a waste ink tank installed so I am not worried about dumping excessive ink into the waste sponges).
The differences was remarkable - though there was still slight banding - maybe should have soaked longer (1 hr perhaps?) - I may repeat if it remains an issue.
Additionally there were large solid deposits on the left side of the print head which were responsible for scraping heavier weight photo paper. These dissolved in the Windex too.
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
1,732 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
