Question about Refrigerators
Metallic tasting water from new water dispenser
  • 28 Answers
As stated above, this generally means you need to change the filter and or the water line. Also if this does not work we have a whole section of our website dedicated to water contamination, causes and solutions located here http://www.freshwatersystems.com/s-262-filters-by-contaminant.aspx
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} FreshWaterSystems 1.877.335.3339 http://www.freshwatersystems.com
Posted on Jul 28, 2009
    Champion:
  • 363 Answers
Was the water filter also replaced. Was the water line replaced
Posted on Jul 26, 2009
How do I clean my ice maker?
Curious, does your refrigerator have a water dispenser? How does water taste from it? Your ref. has one water supply for both ice and water. Changing filter was a good start but if it's been over a month, there's something else going on. I would look and see behind your ref. and look at the water line. I've run across a bad plastic tube that causes a bad taste. If you have a plastic one, change it out with a new one. Also, ice absorbs food odors from both the freezer section and refrigerator sections, so check your fridge for bad food. Bell green peppers are the worst, they'll leave a metallic taste. Good luck!
Sep 18, 2015 | Refrigerators
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
There is a bad order coming from ice and water dispenser. I changed the filter but it didn't help. Smells like ''dirt''. Thanks, Linda
Replace water supply line with the plastic tubing ice maker line. It fixed mine that had a metal braided line on it that made the water taste kie rubber and dirt,, after that I tried a vinyl braided line.and it made the water taste like garden hose water.. The plastic tubing was the cure. Reply and tell me what you have.
Mar 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice taste like metal and the filter does not need changing
I have a whirlpool refriderator that only makes ice. There is no filter in the fridge itself. The water line in the basement is copper, then it has a valve off of the main line. I originally had installed a stainless steel line running to the refriderator. The order of the ice can be described as a metal tasting taste. I purged the line prior to connecting it. I then replaced it with a pvc line, purging it all so. The taste of metal isn't there but it still has a small taste to it. Prior to having a ice maker, we made ice in ice trays with the sink water and had no issues. Can someone shed some light on this issue please.
Nov 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice smells, and tastes bad...no filter to change?
If you have a silver metal braided line to water source that is your problem. Replace mine with a braided vinyl line and it cured it. ps flush new line for about two minutes.
May 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool water dispenser ...metalic taste
Hi!!! you seem to have a bad water valve in your refrigerator.change your water filter and the water valve on the back on the frig..
Jan 03, 2009 | Whirlpool GD2SHGX Refrigerator
My new Whirlpool Refrigerator the water and ice still stink
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Dec 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water and ice both have a strong metal/mineral taste to them
Remove filter and use dispenser a lot. Chlorine in water may help clean out system that filter is now removing. Not much else you can do other than replace all the water lines and tank. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Water Tastes Funny From Sub Zero Dispenser
It will take about three to four months of using it before the plastic loses it freshness into your water. It has to dissipate the "New Car/Plumbing Smell" so to speak. It.s a normal unpleasant necessity but on the bright side... it does go away with use.
Sep 18, 2017 | Sub-Zero 685/S Stainless Steel Side by...
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
