SOURCE: 2000 pontiac sunfire
I had the same problem. Goodwrench looked at my car for 2 hours could not figure it out. Then they unpluged the body control module and plugged it back in and presto, problem solved.
SOURCE: low beam headlights not working on 2004 Pontiac Montana extended
You headlight lamp have a diffuser mechanism which allows it to flip between the hight beam and low beam feature of the bulb. In fact, you high beam will function even if the low beam is not working.
I would recommend the purchase of the new headlight lamp. It would cost you you any where from $15.00 per unit to get a replacement lamp
SOURCE: how to reset change oil soon light 2005 pontiac montana
Turn key to the on position and press the gas pedal to the floor 3 times.then turn key back off then start it if it blinks at you 3 to 4 times real fast its reset..
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
SOURCE: odd warning light in dash for 2003 pontiac montana
When the wavy light is on with parenthasis around it and at the same time the (!) and (P) lights are on, this indicates a serious brake concern
SOURCE: 2005 Audi A4 2.0T oil sensor warning
These engines had an issue with the oil pick up sceen getting clogged this may be the case. If so the oil pan would have to come off and either replace or clean the screen. It would also be recomended to flush the oil system with an oil flush kit. BG makes an additive that works pretty good.
