Question about Kodak i 280 Path-Through Scanner
Kodak i280 scanners
I have a kodak i280 scanner and suddenly windows xp service pack 2 wont recognize my scanner driver, i have reinstalled formated windows 3 times now and still wont recognize it, changed the firewire card also, but no luck so far, now i have 3 scanners that are doing the same thing ... HELP!!!
Controladores para un Scanner KODAK I200 IEEE 1394 SBP2 Device, por favor me ayudan con esto mi carreo etique@hotmail.com. Mil gracias. No me funciona porque me pide esos controladores. Mi nombre Edgar Tique.
Posted on Aug 01, 2008
  • 1,006 Answers
Check this out :
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Please let me know if u got help and rate this SOLUTION AS FIXYA if ur problem is fixed!
Posted on Nov 16, 2007
Kodak ESP3 printer will not connect with Windows 7
On June 8,2010 Kodak released a new driver for ESP3 printer.
Version 5.3.0 for Window 7
Download it HERE
Jul 08, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Cannot transfer photos from kodak computer to
With Windows XP it is possible to connect the camera and transfer pictures without using the Kodak drivers as contained in EasyShare software. Windows XP contains built-in drivers (Windows Imaging Acquisition or WIA drivers) that will recognize your digital camera.
It is a good temporary alternative to using EasyShare if there are issues with installing the software, as it will at least enable you to transfer pictures to your computer. You will however lose the ability to upload any files or information to the camera, such as:
-firmware updates
-e-mail address books
-the Camera Favorites album which is a feature of some of our newest cameras
Simply connect your camera and use the Device Manager to configure Windows on how to work with the camera:
-Right-click on My Computer and choose "Manage". Click [Device Manager] in the left pane.
-Click the plus (+) sign in front of "Imaging devices". The camera should be listed below it.
-Right-click on the camera and select "Update Driver".
-If you have installed Windows XP Service Pack 2, you will be prompted, "Can Windows connect to Windows Update to search for software?" Select "No, not this time". Click [Next].
-Select "Install from a list or specific location (Advanced)" and click [Next].
-Select "Don't search. I will choose the driver to install". Click [Next].
-Select "Digital Still Camera". Click [Next].
-Check that a program selection window appears. Select "Always use this program for this action".
Now your camera should be accessible via My Computer under "Scanners and Cameras".
Oct 25, 2009 | Kodak Cameras
How do I get a driver for a DVC325 Digital to run on VISTA home?
1. Install the w2k/xp driver using compatability mode for windows server service pack 1.
2. Click into control panel - Hardware and sound - Scanners and camera's - add device. Now select the Kodak and Model and Finish.
3. Click into control panel Device manager and plug in DVC325 Webcam, when detected right click and choose update driver (you'll find the driver automatically installs).
Any Problems E-mail me at Daz2020@msn.com.
Oct 02, 2009 | Kodak DVC325 Webcam
Camera Kodak EasyShare C140 was tested in a Kodak representant and worked OK including the transference of photos to the computer however when trying doing the same at home I receive an advice "ESApp.dll...
Last options that you can do is to reinstall the Software.
First check the compatability of Easyshare, Right Click the icon on your desktop and click compatability tab, then remove all check marks under that tab.
Remove the Easyshare Software from the Control Panel, Add Remove programs
Then Run the clear utility software from the web at this site
www.kodak.com/go/clear
After that restart the PC
Then try reintalling the software from the web
www.kodak.com/go/easysharesw
Make sure that there are no other devices connected to your PC while installing the software, including printers and Scanner.
Aug 26, 2009 | Microsoft Windows XP Home Edition
I280 won't scan!
ImageCalibration means the cameras don't get enough light during their self test.
Please check the following points:
Are both lamps on or one lamp in case you have a single page scanner?
Are the imaging guides (the clear sheets above the cameras) clean?
Are the little white tags on the imaging guides present?
One tag on each imaging guide.
Without this small white tags the cameras are not able to check themself.
For emergency you can apply a small white paper or white insulating tape instead of missing tags to test the scanner.
If the lamps are light, both tags are present please calibrate the scanner with the kodak calibration sheets. You will find the calibration menue in the scanner validation tool. You can get this tool from the Kodak home page.
Jul 15, 2008 | Kodak i 280 Path-Through Scanner
Kodak i260 scanner wont work on vista
This is a non Vista compatable product.
It may run on Windows Vista 32bit Business though.
May 05, 2008 | Kodak i260 Duplex Color Scanner
Kodak i 280 Path-Through Scanner Logo
973 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
