My sandisk c250v2 just says "not enough space for music db. please free 4MB" but I can't locate the mp3 player from my computer to try formatting it. I've also tried running just about every sandisk tool they make for this thing. Also I've had the found new hardware wizard say it detected a new device connecting but it can't install drivers for it. I figure if I can find it I bet I can format it, can you help me?
    Brigadier General:
  • 7,191 Answers
The Sandisk model you have does not require any drivers to connect to the computer if the Computer you are having has Windows XP/ WindowsVista. Just connect the player directly via a USB cable and the player should show up in MY COMPUTER.
If for any reason (mostly errors with USB cable) you are not able to connect your MP3 player to Computer, you can also delete the music files in the player itself.
To delete music files directly from the player, follow these steps:
1. In playback mode, press Submenu button.
2. Select the Delete Song item.
Hope this solves your problem. Best of Luck. Thanks.
Posted on Jul 12, 2009
  • AliTech110
    AliTech110 Jul 12, 2009
    You can also try to manually install the player by using this steps:
    Connect the Sansa player in MTP mode and manually install the device driver:
    1. Click Start select Control Panel then select Add Hardware. OR Click Start select Control Panel then select Printers and Other Hardware and select Add Hardware from the left hand side panel.
    2. Click Next to begin the Add Hardware Wizard.
    3. Click Yes, I have already connected the hardware, then Next.
    4. Scroll to the end of the list and select Add a new hardware device then click Next
    5. Select Install the hardware that I manually select from a list (Advanced) then click Next
    6. Select Portable Device or Windows Media Device from the list, then click Next
    7. Select MTP device, then click Next.
    8. Click Next to start loading the drivers.
    9. Click Finish to close the wizard.
    Then open My Computer to Verify if the device is detected properly
    Also, Check if the device is showing up under Portable devices.
    Thanks.
Please free 4mb
hello sir
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Mar 29, 2010 | SanDisk Sansa c200 MP3 Player
Not enough space for music db please free 8mb
try using this program link
if work please rate my solution like very helpfull and vote me thanks
Sep 11, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m230
When connected to your computer, go to your My Computer folder, and right click on your Mp3 player. You should see "Format Device". This wipes the entire thing. All music will be gone, but it might reset it.
Jun 02, 2009 | SanDisk Sansa m230 MP3 Player
Turns on and then off.
I had the same problem. Just had to re-format.
On PC:
Find your player in the list under "My Computer", then right click and select "Format drive".
It should now work.
If you're on a Mac, try plugging the device into a PC. This should format the player.
May 25, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk c200
I would recommend that you format the device and then load everything back again..you can use your computer to format it..
Let me know if that doesnt work for you..
Please rate accordingly
Thank you
Computerrep
Sep 06, 2008 | SanDisk Sansa e250 MP3 Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
Not enough room for music database please free 4 mb
The device needs at least 4MB of free space.
You need to keep deleting files until there is 4MB less than the total capacity of the device.
Its not syncing because the device is too full.
If removing the 4MB doesnt work. Try formatting the device thru My Computer>Device Name (m200)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
Nov 20, 2007 | SanDisk Sansa m200 SDMX3-512 MP3 Player
My mp3 wont work
Use these instructions only if you don't care losing the stored information. Connect it to your computer. Click on "My computer" then click on right button on your mouse and select Format. This should solve it. Please rate this. Thanks, D.
Mar 21, 2007 | SanDisk Sansa m240 MP3 Player
I need help please help me
DB corruption - see my Sansa Tips and tricks
Nov 22, 2006 | SanDisk Sansa m230 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
 Grubhead
Grubhead
Marvin
Marvin
