What is com surrogate?my laptop says it has stopped working?and i have just formatted my recovery file because i needed space for my D drive.
WD MyPassPort 320 GB partially dead after an attempt to make it Win8 recovery drive.
Maybe you can try to format it to see if you can get the space back. But one thing important is that you may need to backup your files first. If not, you may lose them. Or you may try some file recovery tool after you format your drive. This may be help, I've try it, workable. http://www.uflysoft.com/data-recovery-mac/ Hope it can help and hope you can get back your 320G back.
Jul 16, 2013 | Western Digital Wd 320gb My Passport Elite...
My laptop can detect my hard drive but i cant access the files in it
you can recover files from hard drive with asoftech data recovery program. download the program from
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 27, 2011 | Computers & Internet
I unplugged my laptop from MyBook and when I reconnected I got a message to Format step 1 and update software step 2. It appears that I have erased all of my files from the external hard drive. Can they...
Try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed by an experienced tech remotely over the Internet from a boot cd that you download and the best part is they just ask for donations: http://FreeDataRecovery.us
Jul 31, 2011 | Western Digital My Book Essential Edition...
''COM surrogate has stopped working.................
Sir COM means "Component Object Model". These are basically DLL files which are used for system tasks and if they get corrupted then you get same problem. For solving this you need to repaid your windows using windows disk.
Jul 21, 2009 | HP Computers & Internet
My D drive has a recovery file which is of 2.93 MB file and when i see the space of my D drive it has only 1.60 GB space out of 8 gb.why is that so and now i have formatted it. what shall i do now?
omg nooooo! hp makes that drive there because it has the recovery tools you need incase you have to reboot the computer to manufacturer state...damn! however since you already formatted it you erased everything on it! so for now its just extra space, btw stay on the drive c it holds the rest of your memory
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_32392698f23d119d
Jul 12, 2009 | HP Compaq Presario CQ50Z Notebook
Com surrogate has stopped working.
find the link for the software u need on this website http://vistatipsforall.blogspot.com/2007/05/com-surrogate-has-stopped-working-error.html
May 31, 2009 | HP Computers & Internet
Com surrogate
These should help:
http://www.howtogeek.com/howto/windows-vista/fix-for-com-surrogate-has-stopped-working-error-in-vista/
http://www.superbdevelopment.com/forums/general-tech-talk/3600-windows-vista-com-surrogate-has-stopped-working-fix-solution.html
http://www.mydigitallife.info/2008/06/13/how-to-fix-com-surrogate-problem-when-opening-video-format-files/comment-page-1/
Error message: "COM Surrogate has stopped working."
COM objects are often defined in Dynamic Link Libraries (DLL files). The Program file for COM Surrogate is actually dllhost.exe that can load a DLL and make its objects available to other programs.
The COM Surrogate error message is often related to codecs and other COM objects that aren't fully compatible with Vista. These are installed by other programs. The most common culprits are DivX and Nero. The first thing you should do is upgrade to the latest versions of these to see if that fixes the problem. Another possible fix is to disable thumbnail previews in Explorer. To do that:
In Windows Explorer, click Organize, then select Folder and Search Options
Click the View tab
Check the box that says "Always show icons, never thumbnails"
Click OK
To help troubleshoot which codec(s) might be causing the problem, you can use a free tool called InstalledCodec. You can use it to disable individual codecs one at a time.
You can download it at http://www.nirsoft.net/utils/installed_codec.html
Hope that helps
Mike
May 13, 2009 | Dell Inspiron 1521 Laptop
Solution to recover files after formatting
There is a solution to recover formatted, deleted data recovery through a software called "Ontrack Easy Recovery" from this you can recover in RAW format also. Make sure after deleting or formatting the drive don't install any softwares or write other data. This will overwrites the traces of your old data. So you can't get back data completly.
Hope this will be usefull...
Thanks & Regards
Nanda Kishore.
Mar 06, 2009 | Hitachi Deskstar® T7K500 320 GB Hard Drive
Computers & Internet Logo
128 people viewed this question
Alun Cox
David Payne
David Payne
