Question about JVC AV-27230 27" TV
Television want turn on
I have a 27'' jvc television an it want turn on...there's a red blinking light thats flashing on timer....i turned the tv off and back on but it just keep doing the same thing... don't have the remote for the tv, so before i take it the a repair person, can u give me some suggestions on how to fix this...
  • 934 Answers
Re: television want turn on
In a large number of failures with these symptoms it's usually the HOT (horiz. output trans. Q522, which is a 2sd2499) and the regulator (Str30134), together with fuse F902 (Gma 1.25a). Not an expensive repair or that complicated if you're fairly good with electronics and know how to solder correctly. Otherwise take it in and have it repaired professionally - it's worth it...
Posted on Dec 07, 2007
I have a 27" JVC television an it will not turn on....there's a red blinking light that flashing on timer
Posted on Dec 15, 2007
0 characters
3 Points
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Tv won't turn on
You can try checkin the fuses I had a problem like that with my stereo receiver took it apart changed the fuses works great
May 06, 2009 | JVC AV-27530 27" TV
The tv turns on and back off and the on timer light blinks on
Try to reset everything in the menu section to reset the timer for tv some how was activated and needs to be turned off.that might help!!
Mar 01, 2009 | JVC AV-27920 27" TV
Tv shutting off timer light blinking
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Feb 19, 2009 | JVC AV-27530 27" TV
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
JVC 27" D series
there is another problem that requires a tv repairmans expertise when the timer light flashes continuosly ,and the power is not restored.
Apr 21, 2008 | JVC AV-27D502 27" TV
it could be a memory error or a main power supply malfunction.please contact the nearest repair shop.
Jan 07, 2008 | JVC AV-27230 27" TV
Tv wont turn on only clicks and then flashes red timer light
Well, I have found out that the number of red light blinks is a "blink code" that indicates the nature of the fault with the TV. Usually these are various failures of internal fuses or circuit boards. There's a fair amount of information on threads at on this, so try searching there. Teh specific codes and manuals are usually it seems under license from Sony and not available for free to the public. Sorry!
Oct 17, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
Jan 12, 2007 | JVC AV-32FA44 32" TV
JVC AV-27820 27" TV
probably some cold solder joints. take your time and check over whole circuit board and re-solder what looks bad.
Jun 10, 2006 | JVC AV-27820 27" TV
JVC AV-27230 27" TV Logo
456 people viewed this question
Top JVC Standard (CRT) Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a JVC Standard (CRT) Television Expert? Answer questions, earn points and help others
