Question about GE Refrigerators
Refrigerator is somewhat cold, but the Freezer doesn't freeze ice?
    President:
  • 942 Answers
Hi...
If you want to fix your problem, you need to check this:
  • Check the temperature settings
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condenser coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Hope it may helpful for you!!
Regards
PCmania
Posted on Jul 12, 2009
Freezer not cold enough to freeze ice cream and bread.. I have setting at coldest. What else should I check?
First check the manufacturers website for troubleshooting. When refrigerator or freezer not cold enough, typically the problem is the freon is low or a more expensive repair is your compressor might be on it's way out! Sliding Pull Out Shelves Denver Colorado
Mar 09, 2017 | Refrigerators
I have a stainless steel top freezer ice make. the freezer seems t somewhat works but my refrigerator stopped getting cold. what should i do?
Check the fan in the refrigerator section, see if it's blowing air.
Next is the thermostat which you've probably already tried changing. Either one of these could have ice buildup making them not work correctly, so take everything out of the unit and use a house fan blowing into the refrigerator section to melt things out for a couple days. A hair dryer used on the areas will speed things up, but there's a risk of shock. Also the fan or thermostat may need to be replaced. (put your food items in another freezer/refrigerator as they will thaw and warm up within the time it will take for you to try to melt the ice out.)
The fact that the freezer is still working means that your compressor is working and the system isn't out of Freon.
Sep 07, 2016 | Stainless Refrigerators
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
The freezer compartment doesn't work properly.Ice is formed on the back and food won't reach freezing point. ????
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhkgjd
Jun 09, 2009 | Maytag MZD2766GES Side by Side...
Bottom freezer "on" but not freezing and not making ice
Refrigerator running but not that cold, freezer running also but not freezing at all. Also not making Ice
May 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
