Question about Vizio VW32L 32 in. LCD HDTV
I have a pin like chip on my screen that I hit with something. It is just annooying seeing it. It is about the size of a head of a pin. Any way of covering it to blend in or do I have to look at a new screen
    President:
  • 563 Answers
Unfortunately, if that's an LCD, you can't replace the screen. The panel, as its called in the industry, is actually more expensive than the whole TV. Weird I know. But if you have a chip in it, you'll have to live with it. There is nothing available to treat that in order to make it less noticeable.
Posted on Jul 12, 2009
The direct drive head does not fit...we don't know why, please explain as we have just opened the box it is brand new.
If there is a problem of any kind with the physical parts then it is recommended to take it back to the place of purchase.
Alternatively, please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
Oct 26, 2015 | Dyson V6 Absolute Bagless Cordless Hand...
How do i change the font size on the vx 520
http://www.1nps.com/content/images/product_docs/Verifone_VX_520_Installation_Guide.pdf
Nov 21, 2014 | VeriFone Vx 520 Dial 160Mb, New
Wont record
Probably the pins in the video head are broken. you have to change the video head.
Mar 04, 2013 | Canon ES400V Camcorder
What's the difference between pot size and no-limit poker?
As intended from his name, no-limit pokeris a poker without any restrains or limits in any part of the bating process,you can bet on all the chips in front of you (all-in) in every step of the way.In a pot-limit poker the maximum bet is the amount of chips that arecurrently in the main pot, and you cannot choose freely how much chips you wantto bet on. On both pot-limit and no limit the minimum raise amount is to doublethe bet of the last raise behind you.
Jul 23, 2012 | Furniture
I am getting a F6 error when i try to turn on my Panasonic SA-PT760 home theater system?
Hello!
the problem with this error is faulty DC regulator I.C. chip, next to power module I.C. It's a hybrid chip and fatigue causes pins to break off chip's base. Anyway, it's a replacement part, you must have technician skills to replace it, plus some electronics tools. I don't remember the part#, but you'll find it at "panasonic.com/parts". Enter your model# and you'll see the list of all parts. It might be "STK" or "STR" at the beginning of part#. Better to open the unit and look up yourself. It's size about 2 by 1 inch, landscape oriented, with 10-15 pins connecting to the board. Don't try to just re-solder that chip. It's not a chip to board, but chip to pins failed connections. I've tried to re-do those pins, but without any luck. Chip might already died. good luck with your project.
Thanks,
Alex.
Jan 18, 2012 | Audio Players & Recorders
I need instructions on removing links from a Fossil Stella watch
you will need some sort of tool for a pin pusher to actually remove the pin from watch . It can be a strong needle of some sorts but I suggest getting an actual pin pusher to prevent from damaging the watch or hurting yourself.
if you look inside the watch band itself you will see on the links an arrow pointing one direction. That is the direction you need to push the pin since the pin head is larger and cannot be pushed the opposite direction .
On the side of the watch links you will see a small circle endented with a pin head. That is the link pin. Place your pin pusher or other similar sized object and with a small or jeweler hammer slowly and lightly hit the pin pusher down until pin comes out of opposite side , you can use tweezers or needle nose pliers to pull pin all the way out
There are some pin removers that screw also or just push down to pop pin .
Once out repeat process until you have removed enough links that watch fits comfortably. Then slide pins with head of pin entering the side where the arrow on back of link is pointing to. Once all the way in gently hammer rest of pin till flush with link .
Oct 17, 2010 | Fossil FS2919 Wrist Watch
I have a Samsung HLR5067W. I get green plaid
If you can afford it, replace the digital board, or the problem may be connections on the DNIE chip on the digital board, near the DVI connector at the back side of the board. Apply pressure to this chip. It is a BGA type (Ball Grid Array) that has pins underneath that contact points on the board. This is becoming common with high density ICs where external pin connections require larger size chips, tighter spacing, and geometries that are not efficient for the design of the chip. There are good reasons to use BGA, but they can be difficult to solder properly. Apparently, Samsung has had some issues with this chip. One solution is to try to re-flow the solder. I don't suggest this for anyone without the right equipment or tech expertise. It is very easy to heat the wrong parts or overheat the chip, board, or related parts. The board is encased in a metal housing with holes. Look for something that might fit between the chip and housing to put some pressure on the chip, like a bolt. Fit it in, then push the edges of the housing down to where you can put the screws holding it all together back in. There will be significant tension on the bolt, with the larger hex head end standing on the chip and the tip of the screw fitting against the metal housing (bolt standing on its head on top of the chip). Use a little pressure to get the screws back in, which will be good, as it will cause the housing like a large spring pushing down on the bolt, which will put a great deal of pressure on the chip. Simple solution if this is the problem.
Best Regards,
Beach TV Repair
Dec 06, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
This set has green plaid screen on all analog channels. HD channels look pretty good. Changed the analog board, part # BP94-02049E. No change. Which board is it?
This is the digital board causing the problem, so replace that board or try this - the problem may be connections on the DNIE chip on the digital board, near the DVI connector at the back side of the board. Apply pressure to this chip. It is a BGA type (Ball Grid Array) that has pins underneath that contact points on the board. This is becoming common with high density ICs where external pin connections require larger size chips, tighter spacing, and geometries that are not efficient for the design of the chip. There are good reasons to use BGA, but they can be difficult to solder properly. Apparently, Samsung has had some issues with this chip. One solution is to try to re-flow the solder. I don't suggest this for anyone without the right equipment or trechnical expertise. It is very easy to heat the wrong parts or overheat the chip, board, or related parts. The board is encased in a metal housing with holes. Look for something that might fit between the chip and housing to put some pressure on the chip. A small bolt might fit between the chip and the metal housing above it. Fit it in, then push the edges of the housing down to where you can put the screws holding it all together back in. There will be significant tension on the bolt, with the larger hex head end standing on the chip and the tip of the screw fitting against the metal housing (bolt standing on its head on top of the chip). It will take a little pressure to get the screws back in, which is good, as it will use the housing like a large spring pushing down on the bolt, which will put a great deal of pressure on the chip. Simple solution if this is the problem.
Best Regards,
Beach TV Repair
Nov 10, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Tv repair
Hi.
Nice easy repair you have a dry joint on the frame o/p chip.
Just resolder pins on the chip & its repaired.
Oct 21, 2007 | Toshiba CF27H40 27" TV
Panasonic PT-47WX53 G
My TV too got a "bow" at the bottom of the screen. Seem like many suggested replacing this STK chip and also it's $10/each so I went ahead buy 2 to replace the 2 in my TV.
Below is a pic of the inside of my projector TV with the STK-392-110 circled in green and as you can see it is easy to ID due to the HUGE heat sink that it mount on to help dissipate the heat. (sorry for the small size since Fixya limit the file size to 150KB)
I unplugged the TV for more then 3 days and that seem to discharged most of the components.
So here are the steps I take to do the fixing.
1) Before I even order the chip I open it up to verify the part number and it was STK-392-110. Did many research try to find as much as I could about this chip and make sure I order the correct one... so I made the order. While waiting for the product, the TV had been unplug ever since.
2) Well, in order to even get to the inside I need to dismount the back panel. So it had stayed open ever since, of cause out of reach of children.
3) The components arrived and I prepared:
- soldering iron
- solder
- heat sink compound (used mainly to fill in a good gap for CPU heatsink inside computer)
- and solder sucker (the sucker later I found to be useless).
- Flashlights
- Screw driver
- Plier.
O, and my brother offer his help which I found to be very useful. My 2 hands weren't enough to do this work.
4) Removed the 4 screws which I marked with the yellow arrow inside the pic.
5) I didn't want to remove any cable afraid that it might create other problems but had to remove about 3 cables to make it easier to lift and move the board around a little while fixing.
6) Removed 4 screws that mount the chip to it's heat sink using a very short screwdriver. Very little space to work with.
7) It was extremely hard to remove the old chip with the board still cabled to the TV. Many times I was tempted to disconnect all the cables. What prevent me from doing so was I couldn't think of a good way to document all the cables that I disconnect and there are just too many (IMO). I did take many pics just in case.
Anyway, what I did might not be the best way but it worked. I tip the chip back and forth to weaken the pins to a point that it broke. It took forever but it did work. After the chip broke off that I can desolder and remove each pin with the plier. Again with the little space to work with that made me want to remove it from the TV. The pins holes were still very messy and full of solder. My brother came up with a way to clean the hole using stripped wires. When the stranded strip wires touch the liquid solder, it help suck the solder out of the hole. I'm sure there are better ways to clean the holes.
8) We had a little hard time putting the new chip in b/c a few pins bended a little and not align with the holes on board. And when added the compound to the chip, it made it even harder since now the chip need to stay away from the heat sink or else it'll stick to the heatsink. Finally we got the new chip in the holes on the PCB with the compound and all, so it just a matter of screwing the chip onto this heat sink.
9) Turn on TV and pic is 99% perfect again. Why not 100% U might ask.. b/c I saw a tiny out of align colors on the left of the screen. Not very noticeable but I can see it when I pay close attention.
Cost for the two chips were $20 included shipping. Hey, it's a lot cheaper then buy new TV and only 2 chips trashed instead of the entire TV. Anyway, I think I knew which chip went bad. Because one chip had hardly any of the compound. This compound help the transfer of heat to the heat sink.
Hope this help someone.
Sep 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Vizio VW32L 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
