Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter 44155c reads wrong temperature. It reads about ten degrees off. any way of fixing this?
3 Suggested Answers
  • 52 Answers
SOURCE: Hunter 44155C Thermostat
Try calling hunter directly at 1-888-830-1326 to speak with a live support representative. If you are still having problems.
Posted on Jan 29, 2008
drifterK
  • 4924 Answers
SOURCE: I have a hunter 44260
probably the temperature in the area where the thermostat sensor is placed is hotter ...so .if you want a higher temperature ..just set it with 5 degrees higher..and see what 's happening ..I think this will make it get to 70 ..
Posted on Jan 11, 2011
Why is Hunter thermostat temp is wrong ?
The most likely problem is the wall on which the thermostat is mounted. The thermostat is designed to read the temperature of the space in the room, but if the wall is exceptionally warm or cold it can really throw off the actual reading.
Options might be to stuff insulation into the wall behind the thermostat, or relocate it to a wall that is more consistent in temperature with the actual temperature in the room.
May 11, 2014 | Hunter Fan Company 5/1/1 Programmable...
Hunter model # 44155c - set on 73 - cool air comes out- but never kicks off and never gets down to 73
Check the temperature drop from your return temperature to your supply air temperature. Your supply air temperature should be 16 - 20 degrees cooler than your return air temperature. If it is not, your problem may be with your air conditioning unit and not your thermostat.
Prior to calling a service tech, here are some items you can do that may correct the problem for you:
- Ensure your air filter is clean and properly in place
- Ensure your evaporator and condenser coils are clean......clean as necessary.
- Ensure your return grilles and supply registers are unobstructed.
- Ensure your ductwork connections are tight and undamaged.
I hope this information is very helpful to you moving forward.
Jun 12, 2010 | Heating & Cooling
Bought 44155c hunter thermostat air won't turn on.
If unit worked before you tryed changing t-stat then its possible the t-stat wires are shorting each other out.take t-stat back off cut back wires a good 6 to 10 inches or if you dont have that much wire to play with just cut back as far as you can and make sure there is no bare wire touching each other ,then just to test unit to make sure its working ok twist yell.,red,green together this should bring both units on and should blow cold.if this works up to this point on the new stat read directions closely there might be a jumper wire in the stat that needs connected usually from y1 to w1 you would install a jumper wire .see if this helps if not write back i have 1 other solution.i hope this helps
Sep 14, 2009 | Honeywell Programmable Thermostat Heater
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
Air and heat have both been running on Hunter 44155C
There should be a switch on the thermostat.
AC-OFF-HEAT
And another switch
FAN ON-OFF-AUTO
Normally, you just set it for heat or AC and set the fan for auto. If it isn't wired correctly, the switches won't make any difference. It will either run all of the time or not at all.
Feb 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Need help !!
have you tried there web site for the wireing instructions or manual to installing it.
Programmable thermostats at discount prices at
hunter-thermostats.com.
riz.
Feb 17, 2008 | Hunter Fan Company 5/1/1 Programmable...
Jan 26, 2008 | Hunter Fan Company 5/1/1 Programmable...
Installing a Programable Thermostat
give me the wire colors from the white rodgers and how they are connect to the white rodgers .. The white rodgers should be marked on the back where the wires connect. I can then tell you where to hook each wire to on the hunter.
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
468 people viewed this question
Top Hunter Dryers Experts
Joe Paxton
Level 1 Expert
Paul Bade
Craig Butler
Craig Butler
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
