Question about Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp LC-37SB24U power light is blinking but there is no image or sound
    President:
  • 563 Answers
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 12, 2009
    President:
  • 942 Answers
Hi..
Diagnostic code meaning;
Count if how many blinks at the power:
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
  • Hope it me helpful for you
    Regards
    PCmania
    How do I fix Sharp TV LC-37SB24U?
    These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
    http://electro-medical.blogspot.com/
    If blinks continue without any pause, the main board is faulty.
    Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
    Apr 14, 2016 | Sharp Televison & Video
    Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
    Sharp TV - Flashing OPC & Power Lights - YouTube
    ? 0:50
    https://www.youtube.com/watch?v=BH1OcQ6dIEE
    Jul 1, 2011 - Uploaded by Tweetssun
    Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
    Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
    www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
    Feb 8, 2012 - 7 posts - ‎3 authors
    We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
    Oct 14, 2012
    Sharp hd tv blinking power no picture - Digital TV
    Jan 7, 2012
    More results from www.tomsguide.com
    Missing: 32dv22u
    Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
    www.normsweb.com/tektips/42dh77.shtml
    Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
    Sharp LC-37SB24U power comes on no picture and then power light flashes
    Sounds like bad capacitors on the power supply board which is a very common issue for all flat panels. You can get repair kits and also replaceent power supply boards from www.tvrepairworld.com
    Dec 12, 2012 | Sharp Televison & Video
    My sharp LC-37d62u display problem
    This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
    Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
    Sharp lc-37sb24u. Flashing Green Light
    Backlight invertor is most likely cause of the problem, in rare occasions defective CCFL lamps could cause similar symptoms. Replace defective parts, reset lamp error counter and you good to go.
    Dec 01, 2009 | Sharp Televison & Video
    Sharp lc 37sb24u both power and ocp are blinking. power power power and ocp power and ocp power and ocp repeat forever.
    I have the same problem. I can get the video by pushing the power button on top of the TV after using the remote and getting the power and ocp light dance.
    Nov 16, 2009 | Sharp LC-32SB24U 32 in. LCD TV
    Two light are blinkin' in from panel. and tv
    This seems to be a common problem. I have the same issue. Repair man says its a power supply (he thinks). When the lights start blinking, press the power button on top of the tv (not the remote) and most of the time it will come on and work. I am going to try to replace my power supply and see if that fixes the issue. If so, I will update this post.
    Aug 28, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
    I have a Sharp LC-37SB24U when I turn it on the power light and opc light just flash but there is no picture or sound
    I have the same problem with my magnavox. i also would like to know. what we already tried was plug it in another outlet, it worked for about a week but now it happened again. if you find out E-mail me @ ml.soliz@hotmail.com
    Jun 04, 2009 | Philips 50PFP5332D 50 in. Plasma...
    Sharp LC-37SB24U will not turn on
    I can tell you 100% that the problem that you are having will be a service issue. I can also tell you that your limited warranty covers in home service from sharp. Give them a call 1-87-SEE AQUOS(the advantage line that will get you through much quicker). or the 1-800-BE-SHARP and let them set you up for service, sharp will take care of that as long as the purchase date of your tv was within 1 year. If you dont want to go through that, I suggest taking the tv back to where you got it from if they will accept it because unfortunately, this problem can ONLY be resolved through service. good luck & keep me posted
    Feb 17, 2009 | Sharp LC-32SB24U 32 in. LCD TV
    Power light blinking green,nopicture lc-32sb24u lc-37sb24u
    This same thing happened to me, but not until I fiddled with all of my remotes, trying to see if it was an input issue, battery issue, etc. I finally unplugged the tv from the wall and plugged it back in. Nothing. Then I went to take 5 minute ****. When I finished, the Power & OPC lights were blinking, and out of sync. I pressed the power button at the top of my TV and got a picture.
    Word.
    Dec 31, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
    Sharp Aquos LC-32GD4U 32 in. LCD HDTV Logo
    1,068 people viewed this question
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
