Question about Roper RAS8445KQ Top Load Washer
Washer is filled but will not wash or rinse, there is a noise when trying to run. It will drain but not spin, and it will fill
  • horsenutz39 Nov 19, 2007
    I would like to thank you for your indepth instruction for solving my problem. Your advice was excellent and exact. I had no problem, it was very easy indeed. I will look for you in the future.
  • 248 Answers
Probably has a bad motor coupler between motor and transmission. Remove 2 screws in front or in back of console on ends. Shake console back and forth while pulling up. It will raise up in front and pivot back. Disconnect plug for lid switch on washer top. Remove 2 gold colored clips with flat blade screwdriver. Make note of how they go in first. Open lid and grab washer cabinet and pull forward, lifting washer cabinet off frame. Remove pump with 2 clips. Remove 2 screws holding motor clips. Remove clips. Remove motor. Look for broken fingers on coupler. Should have 3 on motor and transmission parts of coupler. If not, replace coupler. Very common part.
When re-assembling, tilt back cabinet and put front edge under frame. Then lower cabinet to base. Make sure sides are in frame. Install clips by hitting down with palm of hand. Install connector. Lower and install console screws.
Posted on Nov 16, 2007
  • Gerald Griffin
    Gerald Griffin Nov 19, 2007
    Thank you. Glad I can help!
Smart drive 085
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
Sep 25, 2013 | Fisher and Paykel (IWL12)
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washer help
Check the lid switch. Some units use a safety lock out. If it is not working then the unit will not drain or spin.
Nov 13, 2007 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Washer/dryer combo
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
Roper RAS8445KQ Top Load Washer Logo
82 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
