Question about Refrigerators
I HAVE A 1999 KELVINATOR REFRIGERATOR /FREEZER IS
I HAVE A 1999 KELVINATOR REFRIGERATOR FREEZER IS WORKING ON TOP BUT IT IS NOT KEEPING FOOD COLD INSIDE OF COOLER
5 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Refrigerator not cold enough
check the back wall of your freezer for a heavy frost build up rhis is an indication of a defrost problem also make sure the fan in the freezer is working
Posted on May 11, 2008
  • 93 Answers
SOURCE: Chemical odor in refrigerator/freezer
put coffeee grains or orange peeles this will take the smell away thanks from gilles
Posted on Mar 15, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: fridge is leaking from freezer to top shelf
This is the drain tube that runs in the back of the freezer on the bottom is pluged. Take a sprayer with some hot water in it and flush out the system. Remove the food so that you dont get any of the stuff on it.
Posted on May 21, 2009
garing
  • 998 Answers
SOURCE: Freezer Working Frig not getting cold enough at max setting
unplug 24 hrs with doors open plug in again if it works better you have a defrost problem. it may be the defrost termination switch.. burned out element or bad timer
Posted on Aug 03, 2009
Kelvinator Cyclic 330 not getting cold enough
Empty the refigerator and freezer, unplug it for about 8 hours, leave freezer door open so it will completely defrost. Plug it back in for 4 hours and close doors before you fill it back up with food. If you have a thermometer, check the interior temperatures before you fill it back up. Refigerator should be around 42 degrees F.
Mar 19, 2014 | Refrigerators
My freezer works but my refrigerator part is not cold
The is normally a duct between fridge and freezer which can over ice can take 3or 4 days to defrost with both doors open and unplugged.
Jan 14, 2014 | Refrigerators
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Kelvinator fridge freezer, fridge too cold frosting at back
Fridges that are less then 10 years old have a lot of POWER. To get rid of the frost, wait until you have eaten most of the food up (maybe a few days), then unplug the fridge and leave the doors open. This will take care of the frost after several hours.
From then on, make sure that when your fridge is full, use a higher setting, and when it is near empty or half way full, use a lower setting. Keeping the freezer at a mid to low setting all the time should be fine, because its usually the fridge part that gives people trouble.You will have to judge on your own which setting is best (i.e you can tell when its good based on how cold the juice is in there, etc).
By adjusting the setting based on the amount of food in your fridge, it should prevent frosting.
Hope that helps!
Mar 28, 2011 | Kelvinator KBM5100MB
Hi my lower part nolonger gets cold enough to keep fresh foods yet the freezer is working well
Set dials to middle setttings, if the colder /warmer dial is peffed max cold its max cold freezer!!! so move to warmer and the freezer will give more airflow to the reefer , the reefer is reliant upon the freezer for its cold air.
Nov 01, 2010 | Magic Chef CTB1821AR Top Freezer...
All of a sudden, my refrigerator doesn't keep anything cold like it used to but the freezer still works. We have cleaned underneath but it still doesn't keep anything cold. What could be the problem?
Look for signs of frost on the back side. You probably have a defrost problem of it could be a drain problem.
Your ice box cold air originates in the freezer. A fan pushes down the cold air into the fresh food section. If their are too many items in the freezer the air can be blocked to the fresh food section. If the drain stops up sometimes a puddle forms a slab of ice between the freezer and the bottom. I ave an apartment maintenence man's guide to these ice box's for you HERE. It feature 4 differnt styles of whirlpool ice box's in your size.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 25, 2010 | Whirlpool (ET8FTEXSQ) Top Freezer...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I have also turn the buttons off and on inside the fridge.
Feb 21, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
