Question about Square Electronics Arts Chrono Cross for PlayStation 1
On disc one, two areas in the game wont load. the music continues but i just get a black screen. I had the disk repaired but it still didn't work. What could be the problem?
  • 28 Answers
I had the same problem and tried everything. Nothing works. I actually believe the game wasn't meant to go any further because i've tried it so many times. Maybe buy a new game?
Posted on Aug 08, 2009
On my Kingdom Hearts 2 game for Playstation 2, the game itself will load, but once I leave an area to go into another room/area, for example, the next area will not load. The screen stays black and I can...
Suggest to try this on another PS2 if the issue still occurs.
If the issue still occurs with another PS2 you may have a scratched or dirty disk. The link provided below will instruct you on how to clean your disk or help with the scratches.
Ref: http://www.wikihow.com/Fix-a-Scratched-CD
Dec 18, 2012 | Square Enix Kingdom Hearts II for...
My laptop wont come on
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 02, 2012 | Acer Aspire 6930-6455 Notebook
Toshiba 5205-S705 is giving an error msg boot.mgr is missing..i tried booting from xp through cd rom but didn work tried to boot with usb as well but didn work any solution pls mail prashantaishu@gmai
You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 13, 2012 | Toshiba Satellite 5205-S705 Notebook
I have an asus u52f or also known as the u53f with the windows 7 version i caught a virus n did not have the recovery disc after i ordered from asus n loaded the disc once i cam to the utilities n drivers...
Why didn't you just get rid of the virus which is the easy solution? Or you could have done a System Restore to a restore point (date and time) before you caught the virus.
Unfortunately most times those Recovery Discs don't work. The best Recovery Disk that works is the one the manufacturer puts on your hard drive.
Have you checked your hard drive to see if there is a Recovery Partition on it?
See if you can run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Apr 28, 2012 | ASUS U52F-BBL9 Laptop
Mass effect 3 wont start on my xbox
Hello,You should replace your disc. May be your disc might have some error. Contact the store where you purchased your game and ask them to offer you a replacement Gaming disc immediately.
Nov 11, 2017 | Microsoft Xbox 360 Elite Console - Black
One game (on a disk with 8 games) no longer works on my PS2
Is the disc scratched? If so it may be scratched in an area that contains data for the game. If that is the case, try repairing the disc using a repair kit, bring it to a game shop that repairs discs, or purchase a new copy.
Mar 18, 2010 | Sony PlayStation 2 (PS2) Console
Put in disk in 360. Play Playonline viewer, but screen goes black, and says cannot read disk, need to clean or restart. I did this several times and same result.
I had this problem recently. What happened was you closed the game without logging out of Playonline. The long shut down I call it. This corrupts the FFXI data on your HDD. And since FFXI does not appear in the memory you have to format your HDD and redownload. I can guarantee if you put the disc in your xbox with no HDD that it will read or even place it in an xbox with a HDD that has never had FFXI.
Dec 26, 2009 | Square Enix Final Fantasy XI for Xbox 360
Screen goes black after a while
first thing comes with system compatibility. chk system compatibility with the game
Sep 29, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont read any disk
If you can't hear the disc spin it means that the lens is gone.
Purchase a mechanism KES-400 AAA and replace it (if you do not have warranty).
If the disc spins and does not load it might be the blu ray board. I have one with the same issue and I don't know how to pair a new board with the existing motherboard.
Sep 23, 2008 | Sony Playstation 3 (PS3) Console
Square Electronics Arts Chrono Cross for PlayStation 1 Logo
82 people viewed this question
Top Square Electronics Arts Video Game Consoles & Games Experts
Marvin
Marvin
MegaByteMe
MegaByteMe
Are you a Square Electronics Arts Video Game Console and Game Expert? Answer questions, earn points and help others
