Question about Astar LTV-19BG TV
Ltv-26hbg // Tv was working when I left for a short time, off when I came back. Had been working fine. Now, only red power led and when turned on the light stays red and flashes. Turning the power switch off for a short time then on again: the pwr led blinks red (first rapidly, then slows. then stays on solid.
  • 187 Answers
That symptom indicate the mainboard is damaged and should be replaced.
Posted on Jul 12, 2009
Sharp LC40LE600E wont turn on
Had exact same symptoms as Keran. Turned out to be my daughter had turned the TV off with the other power switch which is a button on the right hand side of the set - we always use the rocker switch on the left hand side and had forgotten about the button. Turned the rocker switch on, then the button and it was back to normal.
Jul 19, 2012 | Sharp Televison & Video
The tv turns off automatically. This time I cannot get it to go back on.
Tv turn on now,have no power LED light indication at all or LED power light indication is flashing now?Yes,than the tv power supply board it is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 21, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Tv turns off on its own. power light now blinking red, tv not on
Unplug,replug,push the popwer buton couples time,see if stable green LED light,should get tv pic& suond back, not replaced the backlight video board it some how die.
Nov 26, 2009 | Televison & Video
43FDX15B No picture, Power light stays on
Just a thought, but check all of the pico fuses for a blown fuse. The pico fuses look like a small yellow resistor. Some Hitachi's are famous for having a blown hi-volt ceramic capacitor and a blown pico fuse.
I think the red led on is a short protect indicator, but I could be mistaken.
Sep 08, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Astar 30 inch model ltv-3001 will not turn on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Astar LTV-3201 32 in. LCD Television
BLINKING RED LIGHT
The power supply seems to have a shorted part if the LED is blinking.
How old is your TV?
Jul 22, 2008 | Astar LTV-3201 32 in. LCD Television
ASTART LTV-26HBG
Are you still having these connection problem? Please call me at 323-767-6030 and I will go through it, with you.
Thank you,
Ivan.
May 25, 2008 | Astar LTV-19BG TV
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Does Not Turn On
I actually ended up with this set. It turned out to be a very nasty short circuit on the audio board. To trouble shoot disconnect PSD5 to isolate the power supply. It's the 3rd connector from the back on the left side of the power supply. If you turn on the tv and now see 5 green leds and the one red led, look for a short outside of the power supply. The short on this set was on the left side of the audio board (which is to the left of the power supply) There was a wire add and a part add covered in wax. The bare wire was touching a ground but you have to remove the wax to see it. Since this may be a change that was made to all sets of this model, it may be a common failure. Good Luck all.
Dec 25, 2007 | Hitachi 50EX20B 50" Rear Projection...
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
Astar LTV-19BG TV Logo
136 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
