Question about Webroot Spy Sweeper (spysweeper) for PC
Thanks to ruffino28. but i did what you suggested and I didn't see any webroot stuff in my registry editor area. NOW what
Please if your have this programm pleomax F2.4 sendit mee with best regards
Posted on Jul 12, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I've had the webroot antivirus spy sweeper for awhile now and recently i get this message saying that i need to restart computer because there was an error or the webroot didn't upgrade. but when i...
I recommend back up all your information and reinstall the system. And after that install the Kaspersky Total. I have been working more than 9 years with it and works perfectly.
I really hope this recommendation can help you.
Dec 04, 2017 | Webroot AntiVirus with AntiSpyware &...
I need to remove my webroot old progam because is not updaying and is not working well could you tell me what to do to remove the progam. note I allready try from remove and change panel an it didn't...
Using 3rd party programs to uninstall tend to work better than using the built in ones. Ccleaner is a free option and Revo is a paid option. These should take care of uninstalling the program and its registry keys.
Jun 26, 2011 | Webroot Spy Sweeper (spysweeper) for PC
I have a Dell VOSTRO 1700 running VISTA, purchased March 2008 (out of warranty). I used the Toshiba DVD Drive only a few times. Since Oct 2009, the laptop unit (softwarewise) does not ''see'' the Drive....
This is becoming a common problem. Let's see if we can save you $150!!
If your CD-ROM or DVD-ROM Drive Appears To Be Missing then you will need to manually edit your registry.
Follow the instruction below.
Click Start Menu. In the Search box, type regedit, and then click OK. A Registry Editor window will open up.
1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2. Expand SYSTEM, and then expand CurrentControlSet.
3. Expand Control, and then expand Class.
4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
6. On the Edit menu, click Delete.
7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:
Are you sure you want to delete this value?
The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry
5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:
The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
8. Exit Registry Editor.
Step 4: Restart the computer.
This should resolve the problem and there is no easy fix unless you factory restore or reinstall the operating system.
Good luck and please let me know if there is anymore advice that you need.
Jul 20, 2010 | Dell Vostro 1700 Notebook
Trying to remove all reference to Webroot from registry.
please solve my problem i want download nero software 6 demo edition but that give me some error after instaltion can u give serial number of this edition thanks Fayaz
Jan 29, 2010 | Webroot Spy Sweeper (spysweeper) for PC
Installing a new antivirus program
if you know registry editor then go regedit find all webroot stuff and delete
Jul 11, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Will not reconize cd or dvd
try this:
Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
Jun 16, 2008 | Samsung SM 352 CD-RW/DVD-ROM Burner
NEC DVD+-RW ND-6500A disappeared from
Log on to Windows by using an account that has administrator rights and permissions. Then, follow these steps. Step 1: Start Registry Editor loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. Step 4: Restart the computer this should solve your problem
Jun 07, 2008 | Computers & Internet
Not able to burn dvd's...please help
try this
then uninstall and reinstall the burning s/w on the system .... thanks
Apr 26, 2008 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Down load problems
hi thomas
try this
Log on to Windows by using an account that has administrator rights and permissions. Then, follow these steps. Step 1: Start Registry Editor loadTOCNode(3, 'resolution');Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
oke
succes for you
cropp
Mar 15, 2008 | Computers & Internet
Webroot Spy Sweeper (spysweeper) for PC Logo
55 people viewed this question
Top Webroot Computers & Internet Experts
Peter Dragonetti
Mike
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
