Just some more detail. When I power on the JVC GR D70U and any time I power on the device it states lens cap is on and the picture both through view finder and LCD is either scrambled or totally black. Playback works fine thoughJust some more detail. When I power on the JVC GR D70U and any time I power on the device it states lens cap is on and the picture both through view finder and LCD is either scrambled or totally black. Playback works fine though
I have the exact same problem but my JVC model is GR-D72U. Let me know if anyone has any solutions. [email protected]I have the exact same problem but my JVC model is GR-D72U. Let me know if anyone has any solutions. [email protected]
I have the same problem, too. I'm going to contact JVC and I'll post back if I get an answer. SusanI have the same problem, too. I'm going to contact JVC and I'll post back if I get an answer. Susan
You can't post conmments that contain an email address.
Apparently this same problem exists on many different models. I have a JVC grd72u. I called JVC @ 800-252-5722. I selected the "Corrective Action Program" prompt from the automated attendent. I spoke to a customer service rep. They are aware of the problem and are fixing it for free, but only until 12/31/07. I suggest you call ASAP and get your name in the computer. If the problem is something besides the CCD sensor, they will call you with the estimate to repair.
JVC are aware of this problem and in the past have agreed to fix it even though a camera was out of warranty. I had the same problem with a GR-D70AS purchased in the Bahrain duty free shop three years ago which was repaired free of charge earlier this year. I am not sure if the offer is still current but it would be worth checking with JVC. [email protected]
Some of the tapes that we get can be problematic so, if you want to record professionally like the TV studios do. Here is what you must do so that you do not lose the information on your tapes. Some of the bad news is that you can not recover anything from your DV tapes if nothing was recorded on them. However the way forward from now on is to record black on your tapes before shooting on them. Here is what you do. Buy a new tape or if you want to use a used tape you do the same. You insert your tape in the camcorder, with your lens cap on that means you do not take your lens cap off and then start recording. What you will be doing is laying black on your tape so that it becomes ready for recording. It means that your tape will now be recorded with black. you can then rewind and start recording with your cap off the true recording. The tapes will not then be problematic. Please let me know if this has solved your problem.
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue.
To see if you have this problem:
Power On your camcorder (make sure the battery is fully charged).
Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible.
Put a tape in the camcorder.
With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice.
Rewind this section of the tape (using tape counter to verify start of your recording).
Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear.
If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
