May just not be good enough antenna to receive the signal--try to with the remote direct enter a channel you expect to see and if it works you can in the menu add that to the memory---manually enter and add each possible channel.
OTA signal? Check your antenna orientation and if there are any tall objects that would interfere with the signal. (See antennaweb.org or tvfool.com for signal directions and distance to the station. antennaweb assumes an external antenna and is very conservative with station information.) Scan for channels with Menu > > (right arrow twice) up or down to AutoScan and hit enter. Use add channels to include stations with the antenna in a new direction.
If you are using the built-in antenna, you may not get digital signals. Try an external antenna (see above sites). Digital signals are enough or zero.
This TV doesn't have a cable tuner so a set top box would be needed for cable stations, check the box directions for the station you need to tune the TV to access the signal.
You do have to program the tv in a different search mode, I just checked online and if you go to google and put in manual for and then your tv model it will give you various options so you can download the manual for your tv, or if you want more specific the link that I found was
http://www.servicemanuals.net/ServiceManual/SAMSUNG/TXC2516+CX/pos1/results.aspx
Before you bought your new TV, was the cable connected to an older TV, and was it working?
When you say you screwed the cable connection to the antenna input, did the cable come directly from the wall, or did it go through a cable box first. If it came through the wall without a cable box, it's possible it's not an active cable account, and you're only getting over the air signals for your local channels (and nothing through the cable). Or, your cable signal might have been analog only, and with the transition this week to digital TV, maybe you're no longer getting the channels broadcast properly.
If you are a cable subscriber, then this problem should be reported to the cable company, and they can do further testing to see what's wrong with your signal.
you have cable and the stations are still snowy? could be tuner do you have a box or directly hooked up to tv, try unhooking box if you have one and directly hook it up to tv if you havent already done so
removed cable at the back of your TV insert any pin metal material like paperlip without the plastic cover and search local channels from 1-13,, if it does,, contact your cable provider.. it may had cable line problems.
Based on your post/description, it would appear that the TV tuner of the RCA is at fault. Chances are the the VHF Low is not working right but the VHF High is. This is an inshop repair probably requiring component replacement. You may want to confirm by checking your TV's setup in the menu, you should have Cable selected instead of Air or STd and do a Memory + (scan and add channels). If still a no go, then back to the tuner suspect.
The VCR will not display any movie since it normally transmits in Channel 3 (which is VHF Low). If there are no other problem with the VCR then you might still be able to use it by connection it to the A/V inputs of the TV.
If the VCR works in A/V mode, then perhaps you may want to save the repair expense of the RCA TV and use the tuner of the VCR to watch TV and switch channels.
Post back should you need additional information.
Good luck and kind regards.
No. Sorry but your gonna need to get a pair of rabbit ear antenna. Hook it to where the cable was and do a channel search. It should find the available local stations for you. Good Luck
