Question about RCA TruFlat 27F520T 27" TV
Hi My RCA TRuFlate tv turn on for one sec and its give sound but no pic just line in mid and turnoff automatically
    President:
  • 563 Answers
G'Day!
Unfortunately, what you're describing is a repairissue. You won't be able to address the problem with troubleshooting.There is a part inside the TV that needs to be replaced. If you'reunder warranty, this will cost you nothing. If you're not underwarranty the cost will likely be a minimum of $200 parts and labor.However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this informationallows you to make an informed decision as to how to proceed fromhere. Please be sure to vote on my response. I hope I've earned agood rating from you today.
Please post a comment if you needadditional assistance so that I can help you further.
Posted on Jul 12, 2009
L32hd31xy12 sound but no pic
Your tv T-con board is defective.
Apr 01, 2015 | RCA L32HD31 32 in. LCD HDTV
Rca d52w23 tv power light comes on then off after about 3 sec. this happens 3 times without pic or sound, then tv stays off
vvghostvv,
You could literally have anything wrong with your unit. RCA standard procedure is to try to start 3 times when there is a fault then lock the unit out. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will walk you through the troubleshooting process as well as tell you where to get any parts you may need.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 08, 2011 | RCA D52W23 52" HDTV CRT TV
Vizio vx42l Tv will come on no pic, after about 60 sec color lines fade onto the screen, tv will not turn off, need to unplug
It sounds like you have shorted CRT neck board, and it you probably would be better off buying a new LCD.
Jan 06, 2011 | Televison & Video
Power problem
it’s the problem of main power supply circuit board.on the circuit board any of the capacitor or ic is gone faulty.so when you turn the tv ON the current passess through the board but cannot pass from that particular faulty part and the board gets overheated and tv turns off automatically.as you mentioned the tv turns on for some seconds.it will not be a major costly .but the board needs reparing to solve this problem.
Thanks.
Jul 13, 2009 | RCA D52W19 52" Rear Projection Television
Pic freezes, goes dark w/sound then back on
By what you have said your color wheel can cause this when it stops running .Pull back off and watch what is happening when you turn set on.
Dec 21, 2008 | Samsung DLP HL-P5663W 56" TV
RCA Scenium HD52W140
I cannot think of anything easy that would cause the symtoms you are describing. Your power supply is working and the deflection bd is good because you have HV. The problem is signal related and all of this circuitry is on the SSB or small signal bd. The difficult thing is when replacing this bd. you must have RCA's chipper check to download all of the ssb eeprom settings so they can be uploaded to the new ssb. I'm affraid you will need a qualifier RCA service tech for this problem.
Feb 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV won't turn on.
The horizontal (line) deflection circuit appears to be at fault. This circuit is responsible for the generation of high voltage (tension) that also drives many of the secondary circuits such as the vertical drive, tuner and sound stages. While the main power supply itself is running, a failed secondary stage will give the symptom that you've mentioned. Replacing the line-output transistor is likely to solve the problem. However, this advice is given with the understanding that you are familiar with TV repair. Otherwise please refer servicing to a qualified tech.
Jan 09, 2008 | RCA TruFlat 27F520T 27" TV
RCA F32450 32" TV wavy picture
Most RCA repairs on your chassis series require a new IHVT,
AKA flyback transformer . Inside an Integrated HVT are diodes
that can degrade and give the appearance of a bad cap....
Of course, you should check the electrolytics with an ESR
meter, just in case....
xformer part # 257805 or Asti 2078........T.
Nov 04, 2007 | RCA F32450 32" TV
RCA TruFlat  27F520T 27" TV Logo
137 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
