Question about Phoenix Gold XENON 600.1 600 Watt Amplifier Car Speaker
I have amono 600.1 amp
R both my outputs on my mono block 600watts it says its not bridgable
    Problem Solver:
  • 14 Answers
If its mono there is nothing to bridge
Posted on Jul 14, 2009
What amp for a Pioneer TS-W304C 12 inch sub
You seem to be looking for an amp made for car audio. There are many brands, but I going to give you the specs for your particular speaker which will help in choosing, not a specific name brand amp, but at least one with the proper power outputs/requirements.
Your speaker, based on the model number you provided, is rated at 4 ohms .Power handling range is 50-300 watts. And a peak of 600watts. That does not mean start cranking 600watts thru the speaker, it will blow. I suggest you acquire a single (mono) channel amp that provides 350-400 watts at 4 ohms.
Hope these specs help you in choosing an amp.
Jan 07, 2013 | Car Audio & Video
What amp for a Pioneer TS-W304C 10 inch
Wow, i just answered a similar question so, pretty much the same answer.......
Your speaker, based on the model number you provided, is rated at 4 ohms .Nominal power handling range is 300 watts. And a peak of 600watts. That does not mean start cranking 600 watts thru the speaker, it will blow. I suggest you acquire a single (mono) channel amp that provides 350-400 watts at 4 ohms. Leaves you a little headroom on the amp, but use caution.
Jan 05, 2013 | Pioneer TS-W304C Car Subwoofer
Is the pyle pla-1200 bridgable?
This appears to be the manual for several amps, including the pla1200
http://www.pyleaudio.com/manuals/PYLEChopperamps.pdf
If your amp is the same as in this manual, it is a mono amp (or one channel) amp. There is no need to bridge with a mono amp as it has only one channel. The diagram specific to pla-1200 is on page 20 of the manual.
Feb 27, 2011 | Pyle PLA1200 Car Audio Amplifier
How do I hook up my infinity 1600a at 2ohms with 2 4ohm speakers?
Placing the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp. Your amp should have a bridging indication. On the connection points of the amp, you should see a mark pointing to the first + and the last -. That will be your bridge and thus utilizing the full potential of your amplifier
May 21, 2010 | Infinity Reference 1600a Car Audio...
Can i bridge rsd60.1 ser#069243867003
Negative a any amp that is 60.1 or 1500.1 whatever it is .1 is a mono amp and needs no bridging. Some mono amps are set up like a 2 channel but they aren't bridgable they just add more options for wiring each individual sub to the amp...
Dec 11, 2009 | Phoenix Gold Car Audio & Video
Subwoofers
This will depend on the amplifiers capabilities.
I will give 2 different scenarios.
#1 Stereo configuration
If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
#2 Mono Bridged mode.
If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Is that ok to do mono on Thump TA1001
yes, it is a bridgable amplifier, if that is what you are talking about. Look at the speaker output terminal and it should have markings on it for stereo output and it will have a line between the 2 terminals to use for bridging it. When you bridge an amplifier it is mono. There may also be a switch on the amp for stereo or bridged. Put that switch in the bridged mode. Connect one speaker to the speaker output and you have your bridged mono amplifier. If you plan on using 2 woofers, it is better and safer to use it in stereo mode with one speaker on each channel.
Let me know if you need any more help,
Dave
Aug 08, 2008 | Thump TA1001 Car Audio Amplifier
Is it not bridgable
This amp isn't bridgeable. It's a mono amp (only one channel). You need two independent channels to bridge. Some mono amps are bridgeable if you have two identical amps but I don't think Kenwood recommends that with this amp.
Jan 27, 2008 | Kenwood KAC-9152D Car Audio Amplifier
How to install this amp properly?
The amp is a mono amp with only one output channel so it cannot be bridged. You'll use one positive and one negative per speaker. The positive speaker terminals are connected together and the negative speaker terminals are connected together so it doesn't matter which you use for the individual speakers.
Jan 09, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Bridging
Yes and no lol. I sold that product about three or so years ago. That amplifier is whats called a mono amp. The outside shows two channels but they are still tied together. Think of it as a hose with a Y on it so two lines can run out from it. Its still the same amount of water whether you use both hoses or not. So bridge it if you want to but it will for looks and looks only. Note that amp is only two ohm stable so be careful what woofers you use. You will want two single 4 ohm woofers for a regular instalation. DO NOT USE Dual 4 ohm speakers Good Luck
Nov 17, 2007 | Car Audio & Video
Car Audio & Video Logo
Top Phoenix Gold Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
Hemant
Level 1 Expert
seankane89
Level 1 Expert
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
