Question about Allegro ABV511
Set clock need to know how to set clock in allegro abv511
Re: set clock
I just did that the other day! If you have the controller, press the setup/menu button and hit clock... However, since you wrote this many months ago, I'm sure you figured that out already lol... Just thought I'd answer, though, since I'm here.
Posted on Apr 04, 2008
0 characters
3 Points
My problem is that when i put a finalized disc from my camcorder into my allegro dvd and vcr combo, it says disc error and spits the cd back out, i have called the disc manufacturer and they said if i can...
Tries play the DVD disc with another DVD palyers with a well known brand name DVD players units Like Toshiba,Samsung,JVC,Sharp,Sony.Because Allegro brand name by small company,probally dose not share their finalized patent codes with another companies.Try buy a another just a basic DVD player only,cost u like $40 for a brand new one.
May 16, 2011 | Allegro DVD/VCR ABV511
I have an Allegro DVD/VCR Moel ABV511. I have an RCE Universal Remote and the code it offers for Allegro DVD/VCR players doesn't work in setting up the remote to control the player. Their code is 5...
There is not really a true 'universal remote.' If the remote is of older design than the set you wish to control, it will not contain the code set you need.
Before you buy another, check the mfr's website for code sets for any given model remote to ensure you aren't buying another one which will end up in a drawer. Unfortunately, this is a very common problem.
Jan 09, 2011 | Allegro ABV511
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
ABV511: how do you set the clock...
1. Switch your TV to Video mode (the one you use to watch VCR tapes)
2. Press VCR on the Allegro remote control.
3. Press Setup/Menu button.
4. The top item in the main Menu on the screen is Clock.
5. Follow the instructions on the screen using the gray triangular buttons on the remote to navigate
May 17, 2010 | Allegro ABV511
Can't record tv programs onto VHS tape....
you need to connect the cable source directly to the vcr and then from the vcr to the tv,and put the channel you want to record on the vcr,good luck
Feb 02, 2010 | Allegro DVD/VCR ABV511
Not able to view the picture
You may need to change the input on your tv, and check the output cables to make sure they are hooked up correctly.
Jun 21, 2009 | Allegro ABV511
When I go to put a DVD disc in, the DVD player will not read, it just spits the disc back out and says ERROR.
sounds like a region code issue, try to obtain unlock codes for the DVD player
Jan 25, 2009 | Allegro ABV511
How to turn off progressive scan on Allegro Dvd Player
yeah.same here.=[
but it only says that for the dvd mode.
Oct 24, 2007 | Allegro DVD/VCR ABV511
DVD & Blu-Ray Players Logo
96 people viewed this question
Top Allegro DVD & Blu-Ray Players Experts
Are you an Allegro DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
