What harddisk does a Sharp AR-407 copier printer use?
Try this site
http://www.sharp-world.com/restricted/products/copier/downloads/select_us.html
and this
Service manuals electronic components datasheets and equipment schematics...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
SOURCE: Sharp -COPIERS - AR-5316
@subscribe
Sharp does offer a linux driver, look for a cups driver.. Sharp offers drivers for mac, linux, hp output servers, as/400, windows etc... of course this varies on model number...
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
SOURCE: I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
