Amazon Kindle Fire HD 8.9" Logo
K
Kay Adkins Posted on Aug 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not turn on. Get a rectangle with an orange rectangle inside.
Steve Luck
Level 2:
Champion:
  • Expert 203 Answers
  • Posted on Aug 07, 2015
 Steve Luck
Expert
Level 2:
Champion:
Answers
203
Questions
0
Helped
45948
Points
497
It may be "freezing up". Press and hold the start button for 10 seconds. Release and wait another 10 seconds. Press to start as you would normally. It may start up but could take a minute or two.
Why doesn't it turn on?
either your charger isn't charging or your battery is bad
WHY WON'T MY NEXUS 7 POWER UP? hOLDING DOWN THE POWER BUTTON FOR ONE MIN WAS NO HELP.
If the above fails, then pop the black plastic cover off using a credit card corner - it actually comes off quite easily. With the power connector at the bottom, you will see the battery - a big black rectangle dominating the left side of the device. At the top right of the battery is a connector with six wires attaching it to the main board. Gently disconnect the battery (use a fingernail or small flat screwdriver to push the connector out). Wait 30 seconds and reconnect. Put the case back on, plug in your charger and your Nexus will now turn on.
How do you take pictures with the digix 840 tablet
click on the icon that looks like a green rectangle with white dots
then click on the icon that looks like a camera
see page 11 section 6.5 in
http://www.contelusa.net/support/TAB-840/TAB-840%20Manual.pdf
1helpful
How to delete or remove all photos stored in samsung galaxy tablet 3 gallery?
Although I do not have a Galaxy Tablet 3, I own a Samsung Galaxy S3 phone and I believe both might use the same technique.
There are two ways to erase the photos from the gallery. I generally use the first one, using a computer although you may prefer the second one that works directly in the tablet.
In general, when you connect an Android device that has a camera to a computer, it will display in the Windows Explorer an Icon with the name of the device, if Windows has the right drivers for your device installed. At the same time, an icon of a USB connection will be shown in the device's screen top bar.
If you click on your device's icon at the computer, you may find one or two folders (in general, "Card" and "Phone" in cell phones" and "Card" and "Tablet" for tablets). The "Card" folder appears if you have an SD card inserted in your device. Depending on where you set up your tablet to store the photos, inside those two folder you will find another folder called DCIM (that stands for Digital Camera IMages). Check on both to locate where your photos are. Then, select the ones you want to erase or select them all pressing CTRL + A and then press DELETE on your keyboard.
The other way is acting on your tablet. Touch the GALLERY icon to open the Gallery app. If you have more than one folder in your gallery, touch on the folder you want to erase the photos, to select it. If you have only your Camera folder, touch and keep you finger touching any of the photos for around two seconds. The photo will be selected with a green mark and a rectangle will appear at the top, close to the Gallery icon, indicating "1 selected". Touch this rectangle and the option to either "Select all" or "Unselect all" will appear. Selecting all photos will turn them all marked. Then, touch the "Trash can" (delete) icon and you will be asked if you want to delete all pictures. Touch OK and they are all gone! See images 1 and 2 attached to this note.
Hope you may find this information helpful!
Regards,
Miguel L. Martins
My ipad freezes when i use multitasking gestures
you should first bring up the ipads performance and then do the multitask thing and of the line goes flat to the top that means u need a new performance update.
Screen wont turn back upright
Swipe down from the top. A band of icons appears. Look for the rectangle (top left I think) This is the Screen Lock Icon. Tap it to turn screen Lock OFF. (Or on the EFun it may be a Wheel icon for screen lock.)
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
