you may have a bad switch ! i could tell you how to test it ,but could be fairly lengthy . do you own a volt meter ? do you know how to use one? should also check for dtc's in transfer case control module !
transfer case shift control switch indicator inoperative - one or more
the indicator lamps circuit consist of 5 individual lamps contained inside the mode/range switch assembly. the following lamps are contained inside the respective range button:
auto 4wd
2hi
4hi
4lo
each time the ignition is cycled, all 5 mode indicators light simultaneously, as an indicator check to ensure proper operation of the indicators. when the ignition is on, the transfer case shift control module illuminates the indicator lamp that corresponds to the current atc gear position, by providing a ground through a current limiting driver.
the transfer case shift control module flashes each indicator lamp after a shift has been requested and continues to flash until the transfer case shift control module completes the shift.
a solid state circuit, located inside the switch, supplies ignition voltage to the lamps. the solid state circuit also receives voltage when the headlamp switch is in the parklamp or headlamp position. when the solid state circuit receives voltage from the headlamp switch, the circuit reduces the voltage that is supplied to the indicator lamps, dimming the lamps when the headlamps are on.
test description
the numbers below refer to the step numbers on the diagnostic table.
- this step tests the transfer case electrical control of the lamp circuits.
- this step helps determine module failures.
- this step tests the affected lamp circuit for an open or high resistance.
- this step tests the lamp feed circuit for an open or short to ground.
these diagnostic procedures will help you to find and repair automatic transfer case (atc) system malfunctions. this service category also contains information for repairing atc system malfunctions. for best results, use the diagnostic tables and follow the sequence listed below:
- perform the diagnostic system check - transfer case. all atc diagnostics must begin with the diagnostic system check - transfer case. the diagnostic system check - transfer case determines the following:
proper service 4wd indicator operation
ability of the transfer case shift control module to communicate through the data link connector (dlc)
existence of atc dtcs
- refer to the diagnostic table as directed by the diagnostic system check - transfer case. the diagnostic tables help enable you to diagnose any atc system malfunction. bypassing these procedures may result in the following:
extended diagnostic time
incorrect diagnosis
incorrect parts replacement
- repeat the diagnostic system check - transfer case after you perform any repair or diagnostic procedure. this will verify that you correctly performed the repair. this will also ensure that other malfunctions do not exist.
How can I view the answer given by Eddie Green?
I can not find his answer to opening the Big Blue wireless Bluetooth Speaker!!!
Thomas Ahlborn [email protected]
