Question about LG L1932TQ LCD Monitor
L1932TQ Fails on Desktop, works on Notebook
Had my computer freeze after removing a portable USB Flash Drive. So I did a force reboot however this time my LG L1932TQ Monitor failed to display anything from a normal computer start up. Instead it came up with the logo, waiting a few seconds, and then went into power saving mode. I tried disconnecting it,cleaning the connector plug and terminal, even unplugged the power cord and still no display coming from the desktop to the monitor. I then checked the monitor on my notebook and it worked, displayed everything on the notebook monitor however when I attempted to reconnect it back to the desktop same thing; analog mode and then to power saving mode. Attempted to connect a different monitor to the desktop and same thing, no picture but works great on notebook. So am I guessing this is a CPU pathway glitch brought on by the USB or something else involving the monitor?
  • 742 Answers
It simply means that your cpu is not giving back signal to your monitor to process, in fact, it is a cpu problem that is why there is nothing to display in your monitor.
Your cpu froze because of that usb thing. the only way to unfreeze it is to manually reset your hardware in this order.
1. RAM modules. If you can unplug your RAM (memory modules) connected in your motherboard, please do it. Just unplug the modules and then plug it back in. if you have 2 rams, then interchange them when plugging it back. this will force your mobo to refresh its resources.
2. CPU. if you can pull out your cpu chip, then do it. this will refresh your cpu setting in your mobo. (mobo = motherboard)
Regards!
Posted on Jul 12, 2009
My Passport Essential making clicking noise
it might be power or data trying to get a connection make sure all power and data leads are securely attached
if this fails you might have a dirty hard driver with the reader arm skipping across the platters on your hard drive
give the hard drive a firm tap on the side to free up the reader arm you might be able to get it going long enough to slvage your data or it might go for a longer time
or you might use the freeze hard drive
http://lifehacker.com/170257/macgyver-tip--save-your-hard-drive-in-the-freezer
hope this helps
Aug 15, 2012 | Western Digital My Passport Essential...
I am trying to retrieve some files I had copied to an 8GB Dane-Elec Twice Memory USB flash device. Even though I don't recall improperly removing the flash device, I may no longer acces the files on...
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Nov 02, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Software disc is too small, macbook pro will not accept the disc
Hi, if the Macbook can't read the Mini discs, you can copy the contents of the Mini Disc to any USB Flash Drive by inserting the Mini Disc in any Desktop Computer's CD/DVD Drive. After copying the Mini disc contents to USB Flash Drive you can install in the Macbook pro. var geo_Partner = '843689b9-ba30-459d-9c4b-876924715b22'; var geo_isCG = true;
Jun 11, 2011 | Targus Portable USB Notebook Mouse &...
Cannot format usb !
What is the full error message when you try to format it?
Apr 18, 2011 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
What do micro cruzer sandiscs do
your micro cruzer sandisk can perform lots of function .
You can copy your data,songs, video files on your flash drive to use it any time any where .You can do this by just following the simple steps :
1. Plug the USB flash drive to a USB port.
2. A USB flash drive icon will appear on the desktop
3. Double-click on your Cruzer USB flash drive.
4. Select the files or folders you want to copy to the USB drive by clicking on them.
5. Drag and drop the selected files or folders to the USB flash drive icon.
Note : Do not immediately remove your drive from the USB port,right click on drive icon in notification area then click on safely remove the drive ,then remove your drive from your computer.
2: You can take backup of your computer on your flash drive
3.You can also boot from your drive if *********** board support boot from from your flash drive.
May 18, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
My pen doesen't work in my portable with vista but works in a computer with windows 7
Hello
Did you encrypt the USB memory drive while it was in the Windows 7 computer? This would prevent any other computer from seeing the USB drive.
Try using the drive on another comptuer - if the 3rd PC fails to read the drive, put it back in the Windows 7 computer and remove the data encryption from the drive.
The following link is from Microsoft TechNet and provides details on how to enable and disable BitLocker encryption from drives.
May 01, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My memory stick plugs in but it doesn't show up on my desktop, so I can't save any work onto it. What should I do?
assuming that u r using a licensed and updated antivirus (i prefer avg/kaspersky) and using win xp pro as os (some os needs driver to b installed manually)..
change or alter and connect to another usb port..see if itz been detected by the system at all..hv a glance into My computer, if any new drive is created..open Device Manager n see if 'Universal Serial Bus Controllers' are present, listed n there is no conflict..if u r using a external usb hub, try replacing..
if all the above fails, try contact ur system admin/vendor for either bios/mother/main board update or defective Removable Media, try replacing....
Oct 30, 2009 | Electronics - Others
Drive doesn't appear on my desktop
try changing usb ports, will force a new hardware check.
Dec 12, 2007 | Maxtor OneTouch III Mini Edition 120GB...
LG L1932TQ LCD Monitor Logo
123 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
