Alright toshiba regza 26lv47 with dvd player. chasis tac0747. the unit will not turn on . all i get is a yellow light flashing three times and repeat, repeat,repeat.all the fuses (6 or 7 of them)on the power pcb seem to be ok. there are two led lights on the main board at the center of the tv. when you first plug the tv in a green led lights for a short while then the yellow led next to it comes on. same result when i reset the unit with all the leds.
    President:
  • 563 Answers
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced and it isn't a fuse. It's likely one of the circuit boards like the power supply board. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 12, 2009
Testimonial: "thank you, that is what i was thinking also."
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
I have Toshiba Regza 32 with DVD and the disk got struck. It doesnt play or eject. But you can hear the DVD is on, is working. The TV works no problem. How I can ejects the disc from the DVD. Please help!...
Hello
As you feel DVD is woking, that is spinning inside, and there is no picture at all, the fault will be with its defective Laser Pickup Unit. It is a common fault , that this unit bcome damaged. No special rason can be pointed out for that. Just put a cleaning disc into the player, and play it for two or three times. If the fault is due to dust or dirt accumulation to its pick up lens, it will be alright after this procedure. If it does not help, there is no other way than replacing the Laser Picup Unit, with same type and number. OK.
Apr 06, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Wont turn on but yellow light is flashing
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Jul 23, 2010 | Toshiba REGZA 47HL167 TV
I just bought my Toshiba 32inch Regza and I don't know how to connect my dvd! What channel does it play on? I'm in the dark..... I read the instructions but am still confused.
On the back of television you will find three slots, two of which are for plugging in dvd. PROBABLY it may be red and yellow in color. Just attach the cords there and press the av/tv mode or anything similar from your remote. It will switch to a separate channel where you can use the player.
Apr 17, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
When i connect my dvd player to TV i only hear sound but no picture
hi there
your dvd player got three cable one red two white
three yellow ok here i go dvd player input plug in the yellow cable in the yellow in put @ the back of your dvd dvd player
the white cable and red cable is your sound the yellow cabe is your picture see that you have a yellow input @ the back of you tv and plug in the yellow in it then it will work
Dec 14, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
My Toshiba Regza 32 inch lcd tv has a serious problem, on occasion the screnn will turn a fuzzy green color and turn itself off, usually a few loud popping noises also occur after it shuts off then the...
Model number means EVERYTHING to a real technician...
As a guess the popping noise could be arcing to ground - maybe from the inverter or one of the transformers on the inverter. The fuzzy green could be decoding the t-con board is attempting as this ground fault happens and shuts the unit off... I' would clearly have this checked before it does some serious damage. An ounce of prevention could save you pounds of cure....
William Rayburn, CET
Premium Technologies
Oct 05, 2009 | Toshiba REGZA 46RV530U LCD TV
Toshiba 26LV47 Bad Disk error
Probably the laser assembly is damaged. Your best bet at this point is to replace the DVD drive. If you feel like you can do it, its not that tough to do. Here is a link to a website where you can order it from...
http://www.partstore.com/Part/Toshiba/Toshiba/75005731/New.aspx
Mar 19, 2009 | Toshiba REGZA 26HL47 TV
Televison & Video Logo
231 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
