2002 Volkswagen Jetta TDI Logo
Anonymous Posted on Jul 12, 2009
2002 jetta TDI- I try to accelerate up a hill and no power
After long road trips (2-3hours) the car loses acceleration power up hills. maintains power on level surface. i can pull over and turn the car off then back on a works fine for a few miles then back to the same problem. Let sit over night and works fine the next day for 2-3 hours.
Ned C Cook
Level 3:
President:
  • Volkswagen Master 3,433 Answers
  • Posted on Jul 12, 2009
Ned C Cook
Volkswagen Master
Level 3:
President:
Answers
3433
Questions
0
Helped
1436847
Points
9966
Count the shifts. It sounds like you are going into overdrive and staying there. Overdrive is too long legged to pull most hills unless you are really flying.. good luck
No power
have the fuel pressure checked as it may be too low at accelerator opening. run fault codes to check for faulty MAP/MAF/VAF sensors.
2helpful
Vw jetta 2002 losing power when I drive
Need More input to where in town , on freeway, hills ect.
First time I experienced this problem.. my 2003 TDI manual Jetta started losing power as I was driving up a hill. Had the accelerator all the way down and was still losing speed. Got better on and off...
Probably time to get the injector pump rebuilt, it's dumping too much fuel into the engine. Or, something is clogging the airway. (sound deadening foam, don't laugh, it happened on my Volvo turbo)
2answers
Losing power in accelation
Fuel filter is probably clogging up (it's common), which restricts fuel flow and makes it hard to make the needed power for acceleration or other high-load situations like climbing hills. Change it and you'll probably be fine.
2answers
When going up a good size hill or under strain (lead foot) on flat ground, my 2000 Jetta TDI seems to instantaneously drop power (feels like going into overdrive on an automatic). It then has no power to...
it sounds like a wire is bad/ shorting out. Put it in a dark garage open the hood have someone start it while you look under the hood if they give it a little fuel you will see an arc from the bad wire.
2003 jetta tdi looses power
could be worn out piston rings!
Missing and backfiring during acceleration and climbing hills.
Could be vapor lock in the fuel system. Next time it does this, stop and try removing the fuel filler cap... Hope this helps...;-)
2helpful
Losing power/acceleration on hills
Change or clean the EGR valve and install a new catalytic converter.
This should take care of the problem.
Jetta will not accelerate up inclines.
good chance you have a clogged cat converter ...with engine running have someone rev engine and see how much flow you have out tail pipe. also if you hear the sound of something rattling inside exhaust that is another tell tale sign
2answers
02 TDI Jetta auto tranny.....car loses power after 2 to 3 hr trip
Could need a tranny service. Be careful who you take it to. Special fluids and tools are required to do it. They could burn up the tranny if they do it wrong.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
