My dryer does not start the cycle. "F01" comes on the display. I can;t find the meaning in the manual. Anyone know what it means?
SOURCE: error code AF Whirlpool cabrio dryer
I found the answer to the code AF also and it means the air flow is blocked. I checked my dryer vent on the outside and it was clear. However when I removed the dryer duct it was clogged just inside the machine. I had washed and dried a blanket that shed alot!
SOURCE: Kenmore Elite Oasis error code F41
I don't see this code often although I can steer you in a good direction, F41 to F47 is error codes for dual motor problems on oasis.
SOURCE: anyone know what code t0 means? Dryer will start
To = Thermistor Open error.
The Thermistor resistance is very high.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Replace themistor if out of range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: the dryer display for the time is displaying "AF".
"AF" means there is an air flow problem within the venting system. There is either a restriction in the hose, outside vent cover, the front vent, or maybe the lower blower assist isn't rotating.
