Buy and sell electronics cars fashion apparel collectibles sporting goods digital cameras baby items coupons and everything else on eBay the world online marketplace
You can locate parts at hunterfan.com or call for parts at (901) 248-3237 This is the technical service number given to me by the hunter rep a few years ago.
If you need a generic globe, they are available at home depot and lowes in the replacement glass section "Angelo Glass" All you need to do is measure the diameter of the "fitter". This is the metal part the glass fits into and holds it, usually with 3 thumbscrews.
E803 (The output voltage of the composite power PCB has a fault.)
Cause Wiring
Composite power supply PCB (J208) Continuity
DC controller PCB
If it does not turn on, see "The scanning lamp fails to turn on."
If it turns on but is dark, replace it (its ends may be blackened).
Correct the connection.
Connect it securely.
Replace the harness.
Replace the DC
controller PCB.
Replace the composite
power supply PCB.
Turn off and then on the main power. Is the problem corrected?
Does the scanning lamp turn on when the Copy Start key is pressed? Or, is it dark after it has turned on. Is the connection between J111 on
the DC controller PCB and J204 on the composite power PCB good?
Is the connection of the connector J208 on the composite power
supply PCB normal? Check the 24-VDC line between
J111 and J204. Is its continuity good? Is there an output of 24 VDC at the J111-1 and J111-3 on the DC controller PCB
try moving the alignment computer backwards with the wheel turned. sounds like the lazer beam is too close and when the wheel is turned it goes out of range,
considering all other aspects of machine work like camber and toe specs.
1>Turn on machine
2>touch PROG (menu on top)
3>insert desired font disk
4>touch floppy icon
5>select font/font size
6>touch each letter consequtively until speeled (use "_" in menu for a space between words/names.
7>When done, touch REP (menu on top)
8> then start to sew by pressing start/stop
Hi, i have installed thousands of Internal Floppy drives and there aint no conflicts between win/95/98/me and xp.
all discs should be compatible, unless you took it from a apple machine for example.
did it work when you put in a new floppy drive?
all the best
John
