Question about PC Game Controllers
How to remove write protect on my usb flash drive
My mp3 player does'nt want to accept files or delete them.
When i send files to it,it says it is write protected
write protected is not letting me save my files
Re: how to remove write protect on my usb flash drive
How can i delete the files on my flash drive
Posted on Oct 15, 2008
Depends on the brand - did you try going to the manufacturers website, downloading a new set of instructions, and reading them?
Posted on Oct 25, 2008
0 characters
3 Points
Why wont it connect?
there is a sync button somewhere on the controller and the usb thing you plug into your Ps3, pres those at the same time continuosly put make a 2 second break untill it connects.
May 16, 2013 | PDP Afterglow AP.2 Wireless Controller for...
I went to my friends house and brought madden 11 I BROUGHT 2 CONTROLLERS to play 4 player he hooked my controlers to his console i have no clue how 2 hook it back 2 mine
there is a small round button (i think near the usb ports or under the disk drive) press that and hold the xbox button in in the middle of the controller. the lights on the xbox will spin and then the light on the controller and xbox should flash and it should be synced back to your xbox.
Sep 14, 2010 | Microsoft Xbox 360 Controller
How to format my laptop when DVD ROM are properly not wirking.
put your windows xp cd in other computer that have cd-rom ,copy the windows xp setup to your usb,turn on your computer plug your usb flash drive,turn off your computer. turn on again your computer and press F9or press (*-*) to select boot device,select removable media and follow the instructions on screen
Jun 22, 2010 | PC Game Controllers
I plug in the usb and its not does not recognize
Hi, Please uninstall any LGS version present on your OS - Then please proceed to clean boot. ( ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software, plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware failures are covered by warranty terms
US/Canada support:
European support:
Thanks and have a nice day ! J -
I have a Twin USB Vibration Gamepad i need the driver for Windows 7
there is no driver for windows 7 as sitek (the chinese manufacturer of the device that sells it as in "white box license" for others to print its logo on discontinued such a device since 2005. Mind you itself has vanished and a new firm has taken over that address.
Thus end of story , problem on relaying on a small time manufacturor , however i do have the xp drivers and they do work , windows 7 would not accept them and insists that the generic driver it uses is up to date (which works fine except the vibration a.k.a force-feed-back wont work)
I am working on a new uproach on injecting the xp driver into windows 7 registry and if it works i'll let you know :)
Mar 05, 2010 | Genius G-12U Vibration, USB, PC gamepad....
I cannot uninstall a pc game called madagascar 2 escape to africa, as when i try, i get a message that reads ''error reading setup initialization file''
restart the PC don't open any thing open add and remove there try to remove...if its not working ...first delet the game folder where you installed ...and try .... to uninstall ... if its not working....... goto run type regedit...>enter...> in registry editer open hkey-local machine then software..>then delet the folder named as as your game..... (becare full if you delet any other thing you have to reinstall the application or full os)
Oct 29, 2009 | PC Game Controllers
Shows an error of USB Device Not recognized and is INOP
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Oct 26, 2009 | PC Game Controllers
What websight do i need to go to so i can download my pictures??
With your computer on and your phone on, plug it into a USB port via the data transfer cable and it should appear in "My Computer". Just treat it as a storage device (like your hard drive, a flash drive, or memory card.
Feb 12, 2009 | Logitech Attack 3 Joystick
Logitech Wireless Controller flashing a red light
Hello There.
That's unfortunate but in the world of electronics from ebay it's not unusual. My suggestion would be to contact the seller and get them to replace the item or refund you.
If the seller is not helpful and you paid via paypal, then you have upto 60 days to make a claim as 'item not as dscribed' to get your money back or a replacement.
If my answer has solved your problem, please rate me on fixya.
Thank you
Dec 26, 2008 | Logitech Wireless Xbox GamePad Cordless...
PC Game Controllers Logo
196 people viewed this question
Top PC Game Controllers Experts
steve morris
steve morris
Are you a PC Game Controller Expert? Answer questions, earn points and help others
