SOURCE: led radio station indicator light out on a lincoln town car
Most likely not. In order to replace the bulb you will have to remove it from the dash.
SOURCE: 1999 nissan sentra gxe headlight problem
do you have the right light bulb? i own a 98 sentre and
it takes a 9004 bulb, but walmarts computer said to use 9007. That made the high beam censor stay on till i replaced it. if you look at the bulb you can tell if it is a dual or single beam bulb.!!!!
SOURCE: 1999 Lincoln Navigator ABS warning light turns on?
One of the ABS sensor's is bad or a hub bearing is bad.Could be front or rear.
SOURCE: 97 Geo Metro will not start
IF you are able to jump the vehicle using cables connected to another car then it is a power issue, if the vehicle stays running after starter you can most likely rule out the regulator, it sound like the battery is weak and dieing, it can be strong enough to run the radio without having the power to start the ignition.
Testimonial: "i will take out and have tested at autozone, thanx"
SOURCE: Battery is fine, no dash lights come on car won't start.
check fuses for dash lights if you use a12 volt tester turn on runnig lights and check dash lite fuse for power the radio maybe on same curcit/
