Question about Sony Playstation 3 (PS3) Console
No picture playstation 3 worked great for 8 mo. using hdmi cable on hdtv tv. now no picture, no sound,you can hear the game loading and all cables are on tight. tryed to reboot many times with no results.
  • 4,102 Answers
Re: no picture
Their seems to be a lot of problems with the ps 3 and they are all basically the same most of the problems are due to the unit over heating i dont think they thought about this properly when making the unit as alot of them are having this problem if you have only had it 8 months it should still be under warranty so take it back and they will replace it for you if the place you got it from wont do this then you need to contact sony and tell them of the problem dont try taking the unit apart yourself as their is nothing you can do to fix the problem as the unit will need a new board as they are all seem to be getting fried this is happening alot if you tell them that you know people who have same problem eventually they will have to address this problem the should replace the unit for you sorry their isnt nothing you can do because it is hard to get hold of spares for these and they can be as expensive as a new one have you tried holding doen the on button untill you here a couple of beeps this resets the console if this dont solve your problem then get in touch with sony a quick as poss as taking the unit apart will void your warranty hope this is some help to you
Posted on Nov 15, 2007
0 characters
3 Points
Sony Playstation 3. There is no picture, only sound through HDMI cable connection to TV from my playstation 3.
Does your HDMI cable was placed properly through the television and in the PS3 unit ? , If Yes then does you HDMI cable have defects ? If No then whats your PS3 ? Slim or Super slim or Fat ?
Oct 26, 2013 | Video Game Consoles
I have a new ps3. It works great on my hdtv with an hdmi cable The problem Im having is I want to hook it up to my older tv that does not have an hdmi port. I tried using the av cable supplied but I cant...
Follow these very simple steps:
Step 1.
Turn the Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The console will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep
Step 3.
Wait for the Playstation 3 display to initialize.
Your Playstation 3 should now display properly and you can get back to your gaming!
Hope this tip helps you out.
Jan 21, 2011 | Sony Playstation 3 (PS3) Console
Iam not able to get a picture from my hdmi cable, but can still here sound. tried three different hdmi cables... please can you help...
1. Your Connections Are Faulty
Quite often, the cause of the no picture problem is a simple one - loose cords. Make sure that the cords are plugged in tightly, both on the TV side and the PS3 side. This is especially true with the HDMI cable connection on the PS3. Often, it looks tight, but you still might need to wiggle it a bit more to seat it correctly. Along the same lines, make sure that the cords you are using are new and match the connections properly on both the TV and your console.
2. Wrong Connection Settings
If you are using the HDMI/DVI cables and you don't get any picture, make sure to check your video ouput settings. If your PS3 thinks you are using standard A/V cords to connect to the set, you'll have issues. The opposite is true too - if you are using the A/V cords and your PS3 thinks otherwise, you'll have the same no picture problem. Make sure you settings match the types of cable connectors you are using.
3. Wrong Resolution Setting
This is also an easy mistake to make that can result in no picture showing on your television screen. For example, if you've been using your PS3 with an HDTV and then try to hook it up to a standard definition television set, you'll encounter this issue. The cure is simple; just go into your settings and switch back to standard resolution and then restart your system. The 720p resolution is the default setting and this should work for most standard definition televisions.
Nov 18, 2010 | Sony Playstation 3 (PS3) Console
Hooked up hdmi cable for playstation 3 an the
You need to to set the playstation back to scart lead in the settings.
Apr 07, 2010 | Sony Playstation 3 (PS3) Console
HDMI green screen
1-HDMI is available in several versions. The PLAYSTATION 3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PLAYSTATION 3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
The HDMI cable is not included with the PLAYSTATION 3. If you are using an HDMI to DVI converter, you may wish to remove this adaptor.
2- The resolution output (i.e., picture quality) of the PLAYSTATION 3 will depend on three factors:
The type of cable used and the inputs available on the TV or display monitor.
The maximum resolution the TV or display monitor can support. The PLAYSTATION 3 can output two types of resolution: HD and SD. Refer to the TV or display monitor's owner's manual to check which video modes are supported.
The maximum resolution programmed into the source material (movie or game). Refer to the software packaging for information on maximum resolution details or contact the publisher directly.
3- Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HMDI setup and/or equipment.
4- Disconnect any coaxial cables at the point closest to the television. Signals sent through coaxial cables may cause interference with the sound and picture outputted from the PLAYSTATION 3 which results in buzzing and humming noises from your display and speakers.
Nov 29, 2008 | Sony Playstation 3 (PS3) Console
No picture, after changing from HDMi to usual port
try to reset the video refresh output by holding down the power button with the switch in the back on position. hold the front power for 13 secs should hear two beeps one 6 secs after the other. now turn the unit back on and the composite cables (yellow/red/white) should work
Nov 13, 2008 | Sony Playstation 3 (PS3) Console
Rocketfish hdmi no sound
Have you tried another cable? Try this one from Amazon:
For future reference there is no difference between a 70$ hdmi cable and a 5$ one unless you are going through walls or over 25 feet.
May 10, 2008 | Video Game Consoles
i have my picture going through the hdmi and the sound going through the scart. plug the scart into the back of the ps3. then the white and red wire are into my tecnics sound system and it works perfectly you just need to set it up in the sound options in your ps3. which is very easy. just select scart in the sound options. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
No sound from HDMI to PS3
go under system setting-->select sound settings-->select audio output settings -->hit x on hdmi-->hit x on automatic-->hit x to enter. This solved the issue for us :)
Dec 04, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
61 people viewed this question
Top Sony Video Game Consoles Experts
Troy Gorman
Troy Gorman
Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
