Question about Brother MFC 210C All-In-One InkJet Printer
Unable to Clean Message on MFC210C
I took my MFC to a technician and he said I need to change the mainboard, could this be so?
    President:
  • 1,197 Answers
Go into maintenace mode by pressing ( Menu * 2 8 6 4 ) within 2 seconds. You should be in the maintenance mode now. Press 80 and scroll down to purge count, if the figure is more than 6000, press 2 7 8 3 to reset the purge count. The printer will restart and everything normal. Good Luck.
or else.....
just follow the simple steps of
1. Unplug your printer
2. press down the menu/set then plug it (just keep oh pressing it down until you see the message error 46 show up on LCD)
3. press 80
4. then look for "Purge", i think its on the 25th when you scroll down
5. then reset the pruge count to "0" by pressing 2,8,6,4
6. then press stop/exit
7. then press 9 twice
if all this doesnt help... it cud be an issue that has to be resolved consulting brother.....
thank you and have a nice day
Posted on Jul 12, 2009
  • Becky Hursh
    Becky Hursh Jan 15, 2013
    I want to Kiss this Guy About right now!!! I've messed with this printer for over 12 hrs & this just fixed it!! Thank You Soooo Much!!!!!
Unable to Clean ! Message on Display Printer Model MFC210C Installed new Cartridges from Brother
Are you using a generic.. That is your problem. Gerenics have not perfected their products for brother ,because I had a problem and I had to go back and buy OEM and my machine works fine
Aug 05, 2010 | Brother MFC 420CN All-In-One InkJet...
Unable to clean,need code to reset MFC210C, I
Error "unable to clean" on Brother MFC Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | Brother Network Ready All-In-One InkJet...
My mfc210c displays an unable to clean message, what do i do
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 18, 2009 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean,check manual
LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or
Oct 25, 2009 | Brother MFC 210C All-In-One InkJet Printer
Still not printing - HELP!
Not sure whether this applies to your exact siuation but may be worth a try:
Brother MFCs self clean excessively and when they've done a set number of self-cleans, they refuse to print and give an error message which leads you (unsuccessfully) to the Troubleshooting section.
There is a work around - you can reset the self-clean counter - but this carries a small risk the waste ink from cleaning that is normally stored insde the machine in a tank/sponge MAY leak out. I've done the work around on my Brother MFC and, so far, no leakage so if I were you I'd take a punt.
Just Google "brother mfc unable to clean" and somewhere in the results will be how to reset the counter - it's all done from the keyboard so no tools required.
Sep 15, 2009 | Brother MFC 210C All-In-One InkJet Printer
Error messaage "unable to clean" on a MFC210c
There should be a number with the error, if it's 46, you need a new ink flushing box. You won't be able to fax until you clear the error.
Jul 01, 2009 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean message
printer brother dcp 115c .unable to clean. what must i do
Jan 19, 2009 | Brother MFC-5840CN All-In-One InkJet...
Cleaning
unable to clean see troubleshooting and routine maintenance. unable to use it from then
unable to clean
Feb 19, 2008 | Brother MFC 420CN All-In-One InkJet...
Unable to print. Error message Machine Error4F
here read this:
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001887&Sympt=How+do+I+clear+the+message+Machine+Error+4F+from+the+display%3f&Model=89&ProductGroup=5&ProductID=MFC210C
Dec 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Cleaning
The waistinktank is full and has to be changed. Buy a new one from a service partner. Dont clean the old one, cause the felt will be as stone afterwards and wont take up any ink! See link how to open printer: http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c See here how to do the resetcode procedure: http://www.fixya.com/support/t139675-need_reset_purge_counter_due_error_46
Sep 18, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
291 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
