Question about Brother Office Equipment & Supplies
When I print three horizontal lines on the paper even I changed new original drum.
    Brigadier General:
  • 8,619 Answers
Hi!
There are so many possibilities due to which you may get horizontal lines while printing. Please check these one by one---
1. The corona wire in the cartridge may need cleaning, although the one in the printer is usually at fault. The corona wire can be reached through the top front slot of the cartridge. Use a Q-Tip.
2. PCR (charge roller) is loose or defective in cartridge or defective toner bin. Change the cartridge as it will get worse.
3. The moisture content of the paper could be too high. Store paper in a temperature controlled area.
4. The transfer roller could be going bad. This is the spongy feeding roller in your printer which is right under the cartridge head when you put it in your printer. You can replace the roller yourself, for under $20.00.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jul 12, 2009
Why is my printer missing lines
I think you need to change your ink cartridge.
Jan 24, 2015 | Brother MFC Office Equipment & Supplies
My printer is printing black horizontal lines down the right side of the paper - what is wrong?
Needs Drum If you pull the drum unit out you will see on the drum different shades of color lighter is wear the lines come from. Buy a rebuilt drum much cheaper and they work, may have to reset the drum count if the change drum lite on...
May 02, 2014 | Brother MFC-8460N All-In-One Printer
Brother HL-1250 owner's manual
Three Horizontal lines indicates a 'Light Burnt Drum'. The drum units are light sensitive. If they are left in the light too long they will be affected and it will show as black horizontal bars. The number of bars really depends on the circumference of the drum some are 2 some are 3 some can be 5 etc.
Solving this you can only replace the drum unit. Check with your local remanufacturing outlet to source a replacement drum unit at a price WAY better than buying new.
Apr 02, 2014 | Brother HL 1440 Laser Printer
There is a horizontal line grey in color
If this a P2035 printer using a toner cart with a drum in it. The drum has been exposed to light or has a smudge on it. take the cart out and look at the drum. This is a round light blue tube located at the bottom of the cart. It is the drum because it is the only thing in the printer that will print a defect three times on the paper. You could also print about 0 black sheets of paper through the printer and it will go away. This is because the drum coating is in layers like an onion. You must get rid of the exposed layer to get to on that has not been exposed to light.
Apr 02, 2014 | HP P2035N LaserJet Monochrome Printer
Hp 2500l prints a dark line horizontal down each page. Can we clean drum at home?
A dark line on the hp 2500 series can come from the drum You can't clean it at home), it can come from a toner cartridge, from the fuser unit and from the optics.
Step one - check if the line in all colors, run copy quality check through Menu and diagnostics, if the line is only on one color your problem is the toner cartridge.
Step two - if the line is on all colors, take the drum unit out and look at the drum, if you see the line on the drum you need to replace the drum unit.
Step three - stop a print in during the printing process by turning the printer off, take out the drum and look at the printed paper under the drum, if the printed page is clear of line your problem is in the fuser.
Good luck.
Dec 14, 2010 | HP Color LaserJet 2500L Laser Printer, up...
I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the second...
Regularly spaced horizontal lines suggest that there is a defect on the drum in the printer. I would suggest changing the drum to see if that will fix the problem.
Oct 08, 2010 | IBM Network Printer 17 Laser
I just changed my laser cartridge and with the new one in my printed pages have two or three horizontal lines on them
does these lines occures when you print something out or just when you copy something?
If it occures when you print out also check the new toner crg. drum ( green roller ) and if the lines are on its surface change the crg. because that means that the cleaning blade is faulty.
If there isnt lines on drum, and printed image is OK, clean the copy glass ( both platten and adf glass ).
Worst case scenarion is faulty fixing film.
Hope that helped!
Aug 13, 2010 | Canon imageCLASS MF5550 All-In-One Laser...
HP P2015 prints horizontal lines across paper
you shuld replace the cleaning blade inside the drum!
Jun 23, 2009 | HP LaserJet P2015x Printer
Dark Horizontal Lines on Faxes
on the drum unit that you put your toner inn, There is a blue or green slide lever move the slide back and fourth 10-15 times. If you have some van air blow that area out ( F.Y.I. if you do this some toner will fly out ) if this does not take care of it the drum unit my be bad,
do a 1/2 print test. copier something with a lot of print. open front cover when the paper is 1/2 way through the machine remove drum. Look art the paper and the green drum if the marks are on the paper & drum then the drum is bad. If not the fuser asm is bad, the part that gits hot when melting the toner on the paper,
Jan 29, 2009 | Brother IntelliFax-2820 Laser Fax
Horizontal line on prints
Put plain paper in the printer and try to clean the nozzles.
-Start->All Programs->Lexmark 5400 Series->Lexmark Solution Center->Maintenance->Clean to fix horizontal streaks.
Steve
Sep 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
116 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
