Question about Ricoh 1180L Laser Fax Machine Black OEM Toner Cartridge - 4,000 Pages - Toner-Cartridge-1180L
Have richo fax 1180L , its given error massage printer error - fuser temperature. What is Fuser? How I resolve this problem. PLease help me
  • Ricoh Master
  • 4,290 Answers
SOURCE:
Printer error fuser temp for 1180l
I presume this is for the Ricoh 1180L?
The most likely problem is that the heat sensor has toner built up on it and it's dirty, so it detects the wrong temperature. There are other possible reasons why this error is displayed so it's best to have a service technician take a look at the machine to determine the exact cause.
Feb 01, 2017 | PRINTER Office Equipment & Supplies
I have a fax machine F550 which is giving me an error message 0550H. Can you please help me to resolve this issue.
i tried looking at the manual. and this is closest thing I could find.
550 9-22 A Standby temperature error 1-Fusing temperature failed to drop to expected level within a given time (15 seconds, 15 minutes, or 25 minutes, depending on mode) after entering standby or lowpower mode. try rebuilding the fuser. hope this helps. goodluck
Apr 14, 2011 | Office Equipment & Supplies
I got the error 50.9 on my hp colorlaser jet 3600 and i've what it said on the screen of the printer and the error it still there. please help me, i need this, my job is in the line. what can i do to make...
Hi hope this helps
the error looks to be low temperature on the fuser
as a repairer of machine I would normally recommend a new fuser unit if you use the machine a lot don't go for a refurbished unit as they just dint last as long but they cost more
hope this helps Ian
50.X FUSER ERROR
alternates with
For help press
A fuser error has occurred.
X Description
1 - low fuser temperature
2 - fuser warmup service
3 - high fuser temperature
4 - faulty fuser
8 - low fuser temperature
(subthermistor
9 - high fuser temperature
(subthermistor)
WARNING: The fuser is HOT. Turn the
printer off and allow it to cool for
approximately 10 minutes before removing
the fuser.
50.1 error - Fuser failure (Abnormally Low
Temperature Main Thermistor), perform the
following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
printer off and remove the fuser. Measure
the resistance between the fuser
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Faulty DC controller PCB. Replace the
DC controller PCB.
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
it if damaged.
3. Break in the fuser heater. Measure the
resistance between the fuser connectors
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
Table 7-3. Numerical printer messages (continued)
338
Mar 24, 2011 | HP LaserJet 3600n Printer
Functional problem sc 541 for richo aficio 1022 photocopier
SC541 = The melting temperature measured by thermistor is less than 71 C
The problem lies in the fuser:
- Thermistor fuser defective or incorrectly installed
- Fuser Lamp failure
Solution: Replace Fuser
Jan 05, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
I have richo fax 1180L , its given error massage (printer error - fuser temparature) i check the fuser its good pls help me to reset this massage
This usually indicates either the heater is not turning on or the fuse for the heater has blown. This is a special fuse at the fuser - it melts at a certain temperature. It usually means the fuser is dirty, needs cleaning or there is a paper stuck in the fuser affecting temperature detection. Fix the heating problem before you waste a fuse.
Mar 30, 2010 | Office Equipment & Supplies
50.4 fuser error
Some suggestions:
  • Turn the printer off for 20 minutes and allow the fuser to cool (this may resolve high temperature fuser errors).
  • Re-seat the cooled fuser assembly (this may resolve other non-temperature related fuser errors).
  • If the printer is plugged into a power strip or surge protector, plug it directly into a wall socket or different circuit (this may resolve errors caused by an inadequate supply of electricity).
  • Try a different power cord (the current power cord may be damaged).
If still a problem, your fuser is faulty and needs to be replaced (typically not a user-serviceable item) by service. Hope this helps.
Jul 21, 2009 | HP LaserJet 5000 Printer
Ricoh 1180L Laser Fax Machine Black OEM Toner Cartridge - 4,000 Pages - Toner-Cartridge-1180L Logo
338 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
