SOURCE: Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
SOURCE: my printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
SOURCE: clean unable 46 error on dcp 135c brother printer
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
SOURCE: my brother DCP-165C clean unable
my brother DCP-165C clean unable 50 problem, i can not use my printer due to this problem, what am i gonna do' pls. help?
