Question about Brother HL-2040 Laser Printer
Lights on printer will not go off when turned on.
When I turn on my printer all the lights come on for the toner, drum, paper and ready and they won't go off. I cannot printer anything.
  • 3 Answers
May ur printer ink is finished. check ur ink in printer.
Posted on Jul 12, 2009
I have an HP 4515 that is printing blank pages. I have tried to replace the toner and the power supply board. Neither resolved the issue. When the paper gets deliver out the paper is warm. This occurs when...
I believe I understand your issue:-
The printer is able to come to ready- your still able to navigate the menus. the printer goes through all the motions of printing except producing an image-
Having the machine print a test page ( internal Print ) tests whether the formatter is still able to generate a digital image ready for the print engine, but does not diagnose the print engine-
1) power down and remove power cord
2)remove the toner cartridge, use a pair of pliers and gently rotate the drum ( within the toner cartridge, a drive gear/mesh can be found on the end of the toner unit)- are you able to turn this drum or has it seized?
if it doesnt replace the new toner with another NEW toner and try again
3) return the power and power up the machine having first disconnected all network connections.
allow the machine to come to ready.
4) ask the printer for a config page ( internal print) and estimate when the paper is immediately below the drum surface ( toner cart) and using the power switch turn the printer off- causing a jam in the centre of the printer - this is ok we do this to see if an image has been generated on the drum surface- remove the toner cartridge and slide the drum protector plate to the side, look carefully at the drum suface ( you should see a latent image of a config page, at this point look at the paper still jammed inside the printer and see if there are any signs of toner ( there should be part of an image allready on the surface ) now if there is an image on the drum but no image on the paper then I would replace the transfer roller and or transfer HVT power unit, if however there is no image on the drum then you have a very serious problem which will require a new laser unit ( but this should really come up with a diagnostic error code)or Primary HVT unit.
Feb 06, 2014 | HP P4515n LaserJet Printer
How do I reset the consumables counter on myBrother HL-2035 printer printer
1.) Turn the printer off.
2.) Hold the 'go' button while turning the printer on. All panel lights should be on.
3.) Release the 'go' button once all lights are off.
4. )Press the 'go' button 2 times.
5.) Pause.
6.) Press the 'go' button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your "low toner" light should be fixed.
Jun 16, 2013 | Brother Hl-2035 Drum
I have a Brother HL - 2040 printer. It has been turned off. Having switched it back on I now have the Toner, drum and paper lamps on and it hasn't warmed up. Does this mean I need to purchase a new...
If all the LED's are flashing and continue to flash for more than 10 minutes with the unit powered up, it needs to be serviced or replaced. (That is toner, drum, paper and the Ready light all blinking -> critical error found in self-test.) If the Ready light is off and the rest of the lights are steady, the toner is out, the corona wire needs cleaning and the paper tray either is empty or not picking up the paper.
See http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_005.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=11 for details on the errors and solutions.
I hope this helps.
Jan 27, 2011 | Brother HL-2040 Laser Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
My Brother HL-2140 Went out in a storm. All three lights just keep blinking no matter what I do. Held down on the blue light button a number of time, restarted computer, turned off printer, reloaded ink...
You can find the usre's manual here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hl2140_all&dlid=&flang=English&type2=-1
1) If the LARGE BLUE BUTTON is blinking:
Data remaining in memory
There is remaining print data in the printer memory. If the Ready LED is blinking for
a long time and nothing has printed, press the Go button to print the remaining data
in the memory.
2) If the TONER LED is blinking:
Toner low
Indicates that the toner cartridge is nearly empty. Buy a new toner cartridge and have
it ready for when Toner life end is indicated.
The Toner LED will turn on for 2 seconds and off for 3 seconds.
3) If the DRUM LED is blinking:
Drum life end soon
The drum unit is near the end of its life. We recommend that you get a new drum unit
to replace the current one. See Replacing the drum unit on page 69.
The Drum LED will turn on for 2 seconds and off for 3 seconds.
4) If the RED ERROR LED is blinking:
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Mar 26, 2010 | Brother HL 2140 Laser Printer
Printer Problems
Hi, it sounds like you need to change the drum. If you are using the High Yield TN660 toner is your printer, then the drum needs changing every 3-4 toners. If using the low yield TN6300 toner then your drum needs to be replaced every 6-7 toners. Hope this helps
Nov 20, 2008 | Brother HL 1440 Laser Printer
Paper Jam
In that case try turning the toner and drum by hand (while it is out) can they turn? check the gears that corresponds to them in the machine?
put a marker on the very edge of the drum and put in after it says ready take out and look at the mark did it rotate?
Aug 22, 2008 | Brother HL-2040 Laser Printer
Won't Print But Ready Light On Fan nonstop
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Apr 04, 2008 | Brother HL-2040 Laser Printer
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Paper light on...!!
Turn the printer off. Take out the toner drum and cartridge. Remove the toner cartridge by pressing on the blue lever on the left side. Check for paper. Replace the cartridge. At the rear of the toner drum is a blue slide lever on the right side for cleaning the corona wire. Move the lever back and forth, left and right, about 30 times. Reset lever to far right side with arrows lining up. Set the drum and cartridge aside. Remove the paper tray and look inside for a jammed sheet of paper. Flip the back lid down and check for paper. Snap the back lid up, replace the paper tray, and replace the drum and toner cartridge. Turn the printer on. Press the ready button 3 times quickly. It should print a specifications sheet. If it does, try printing from your computer. If this did not help, Brother tech support is 1-800-276-7746. Robi
Nov 10, 2006 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
66 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
