SOURCE: Canon MP620 is not recognized by PC
Make sure you do not have it plugged in before you start the install. Also for the next install attempt, plug the cable in to a different USB port than the one you;ve previously tried.
SOURCE: 7410xi Software installed but list of printers does not show it
I used the same web release driver, but I don't think it supports wifi. The driver works just fine if you connect via usb and then run the printer install wizard in control panel, but you need some other software to recognize it wirelessly. Also, go into setup on the printer display and make sure that you've connected to your wireless network. That may be your problem.
SOURCE: the USB port on my
It sounds like an expensive solution, but you'll have to replace the internal port which is probably the system board. Better to buy another printer.
