Question about Refrigerators
I smell amonia when i open the door - Refrigerators
    Problem Solver:
  • 10 Answers
Clean it out good with soap and water unplug it from wall take the cover of and check ur vent lines see if they are leaking cheap fix get gorila tape!!
Posted on Jul 12, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Catalytic converter bad
That is the normal chemical conversion caused by the additives in the fuel. Nothing to worry about.
Sep 17, 2017 | Infiniti Cars & Trucks
Sour smell in kenmore elite top loader
Try putting a cup of amonia in with your detergent,when you wash.
Jul 23, 2012 | Kenmore Elite 20972
Our dometic RM 2350caravan fridge smells like amonia when switched on to ac or dc power. It wont get cold. Help please.andrea
Hi, you have a freon leak in your system, with the caravan refrigerators they use amonia as a cooling media. You need to either have a service person the knows this system or purchase a new one. thanks.
May 18, 2011 | Dometic Refrigerators
My Rm2652 Refrigerator in my Rv just quit cooling. The electric element checks good and heats as well as on gass. I did not smell any amonia odor from a leak and have not taken it out and turned it upside...
You need to have 12 volt supplied at all times to make it work
Check to be sure you have a good 12 + and a good ground.
Lots of times the coolant leaks without you smelling anything Slowly over time
Mar 06, 2010 | Dometic RM2652 Refrigerator
A build up of brown slimy mould which marks clothes after washing. The door seal is stained brown in places and the brown slime is building up in the folds of the doo seal. What can I do?
try manualy cleaning the door seal with bleach and then amonia, ( NOT TOGETHER, ONE AT A TIME )
then pour some amonia into the machine and run it. amonia and/or vinegar work great to clean washing machines. but please note : this should be done seldomly as Amonia is a corrosive towards electrical parts.... hope this helps.
Oct 18, 2009 | Washing Machines
Sweet smell from refrigerator
empty it out and wipe it all down with a solution of 1 cup of white vinegar in 4 cups of water. get all of the nooks and crannies. Then finish up that part of the job by wiping the surfaces with straight vanilla flavoring.
finally remove the lower front grill and clean the drip pan..........that should do it.
Aug 17, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fishy smell in camper fridge
They freon used is mainly amonia,best thing to use is bleach put in spray bottle mix 70 percent water and 30 percent bleach squirt entire fridge let soak then wipe clean let air out as much as possible!!!! :)
Jul 19, 2009 | Zanussi ZEBF277W Bottom Freezer...
Our rv refridgerator/freezer was turned on for the first time since we bought our rv and when the freezer was opened it had a terrible smell of amonia that about knocked me over. Is that smell free on or...
thats because yoiu have a amonia system thats why they say to keep it level to opoerate properly. the smell may be a leak from where someone punctured the evaporator.
Mar 07, 2009 | Refrigerators
Dometic RM761
ammonia smell means the cooling unit is bad and must be replaced.....check out rvmobile.com
Aug 18, 2008 | Dometic RM2652 Refrigerator
Dometic fridge amonia smell.
It is simply a bad cooling unit and that particular piece needs replacing.
I can chose to repair it for around $460 or replace it for about $960.
Aug 02, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
